remote teleworker phone keeps "registering"
Jul 19th, 2008
It used to work fine, but testing coused the problem
Debuging tftp events and ephone register, gves the following
000355: Jul 19 08:49:07.453: TFTP: Looking for CTLSEP001F9E26A32D.tlv
000356: Jul 19 08:49:07.625: TFTP: Looking for SEP001F9E26A32D.cnf.xml
000357: Jul 19 08:49:07.629: TFTP: Opened flash:/its/SEP001F9E26A32D.cnf.xml, fd
7, size 1274 for process 361
000358: Jul 19 08:49:07.801: TFTP: Finished flash:/its/SEP001F9E26A32D.cnf.xml,
time 00:00:00 for process 361
000359: Jul 19 08:49:09.237: TFTP: Looking for /g3-tones.xml
2811ccme#
000360: Jul 19 08:51:59.709: TFTP: Looking for CTLSEP001F9E26A32D.tlv
000361: Jul 19 08:51:59.841: TFTP: Looking for SEP001F9E26A32D.cnf.xml
000362: Jul 19 08:51:59.849: TFTP: Opened flash:/its/SEP001F9E26A32D.cnf.xml, fd
000363: Jul 19 08:52:00.017: TFTP: Finished flash:/its/SEP001F9E26A32D.cnf.xml,
000364: Jul 19 08:52:01.181: TFTP: Looking for /g3-tones.xml <------- STOP ???? DOESN'T CONTINUE.
Any help why it can not locate g3-tones.xml
Thank you
Dimitris
ivillegas Thu, 07/24/2008 - 06:08
It seems that the tftp-binding is not set up correctly. The CME can not find the file requesting by the CIPC end point.
You have to look the new TFTP server's address that you will need to correct on your ip phone under network configuration
Dimitris Mingos Thu, 07/24/2008 - 07:25
Thank you for your replay.
I added the following and that problem was fixed:
tftp-server flash:g3-tones.xml alias United_States/g3-tones.xml
tftp-server flash:us-mk-sccp.jar alias English_United_States/mk-sccp.jar
tftp-server flash:us-tc-sccp.jar alias English_United_States/tc-sccp.jar
tftp-server flash:us-td-sccp.jar alias English_United_States/td-sccp.jar
The remote phone was an 7911 and now is a CP-7941 registered as mtp with the following configuration:
ephone 30
device-security-mode none
mac-address 001E.135D.64E0
username "user9" password 226
mtp
type 7941
The problem is that the phones show "registering".
Any help on that?
Thank you.
Dimitris Mingos Sat, 08/09/2008 - 06:53
The remote phone can download the ringlist and locale, will show the ccme address, but keeps "registering"
Any help?
Dimitris Mingos Sat, 08/23/2008 - 17:59
I am unable to solve the problem!
I am using a site-to-site vpn with 2 pix501.
Can it be an access-list isssue.
The remote phones ip is 10.10.8.24
Office vlan1 (DATA) ip add 10.10.10.x
Office vlan100 (VOICE) ip add 10.10.100.x
Office router 2811 cme 7.0 ip add 10.10.10.1
Closed ports 1720 & 5060.
Any help?
Thank you.
Marwan ALshawi Sat, 08/23/2008 - 18:05
first of all
u need to make sure that sccp inspection is enabled
aslo make sure to include the following traffic in the vpn interesting traffic and allow it aswel
sccp
TFTP
http
this is for voice signaling and phone load
the folowing link will give u a good idea through a nice example address a case similer to yours
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a008080dfa7.shtml
good luck
please, if helpful Rate
Dimitris Mingos Mon, 09/01/2008 - 10:06
I am lost!!!!!
Attached is the confiuration of one pix 501 I am using for site-to-site vpn.
My cme configuration includes the following:
ip dhcp pool DATA
import all
network 10.10.10.0 255.255.255.0
dns-server 80.76.39.10 80.76.33.227
default-router 10.10.10.10
lease infinite
ip dhcp pool VOICE
import all
network 10.10.100.0 255.255.255.0
default-router 10.10.100.1
option 150 ip 10.10.100.1
lease infinite
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip refer
h323
sip
registrar server expires max 3600 min 3600
voice class codec 1
codec preference 1 g711ulaw bytes 160
interface FastEthernet0/0
no ip address
ip access-group 128 in
no ip mroute-cache
duplex auto
speed auto
interface FastEthernet0/0.1
description ** Data VLAN **
encapsulation dot1Q 1 native
ip address 10.10.10.1 255.255.255.0
interface FastEthernet0/0.100
description ** Voice VLAN **
encapsulation dot1Q 100
ip address 10.10.100.1 255.255.255.0
service-policy output output-L3-to-L2
access-list 100 permit udp host 10.10.10.20 any range 16383 32727
access-list 110 permit tcp host 10.10.10.20 any eq 2748
access-list 128 deny tcp any eq 5060 any
access-list 128 deny tcp any any eq 5060
access-list 128 deny udp any eq 5060 any
access-list 128 deny udp any any eq 5060
access-list 128 deny tcp any eq 1720 any
access-list 128 deny tcp any any eq 1720
access-list 128 deny udp any eq 1720 any
access-list 128 deny udp any any eq 1720
access-list 128 permit ip any any
telephony-service
ip source-address 10.10.100.1 port 2000
cnf-file location flash:
cnf-file perphone
ephone 15
video
mac-address 001F.9E26.A32D
mtp
paging-dn 1
type 7911
button 1:71
Any Help will be appreciated!
Dimitris
