Jul 19th, 2008
Is it possible to use CRS script variables as a SQL column name in an DB Write??
The script bellow does not work but if I replace $String_DBColumn with "COLUMN" all works fine.
update "SESSIONS"
set $String_DBColumn = $String_Status
where "SESSIONID" = $int_SessionID
If I try to run the script with $String_DBColumn the exception in the attachement is thrown.
b.hsu Thu, 07/24/2008 - 13:38
You can't use Column name as a value which will be decided at runtime, it should be given while writing scripts.
