No Voice on calls though E1
Answered Question
Jul 19th, 2008
Hy guys,
I will need some help, I have a gateway 2811(1 VWIC2-1Mft-E1, 8 FXO) configured with MGCP and a CCM 6.1.2.
When I try to make a call from the IP Phone to the cell phone, after I answer I don't hear anything (no voice). If I make a call from the cell to the IP Phone all it's ok I can hear the pearson. From time to time when I reset the gateway I have a conversation in both ways but just once, when I hang up and try to call another time there's no voice again. I will attach the gateway config.
Correct Answer by Kenneth Mohammed about 8 years 10 months ago
Hi Michael,
The config you posted was kind of jumbled up, but in reading through it, it doesnt appear that you have media and control traffic bound to any interface. Try adding these commands to your config:
mgcp bind control source-interface [interface]
mgcp bind media source-interface [interface]
Hope that helped
Overall Rating: 5 (1 ratings)
Correct Answer
Kenneth Mohammed Sat, 07/19/2008 - 09:38
  • Silver, 250 points or more
Hi Michael,
Hope that helped
Michael Ciulei Sun, 07/20/2008 - 11:22
It seems that those commands solved my problem. Now everything's all right.
Thanks, Kenneth
pcameron Sun, 07/20/2008 - 06:01
  • Cisco Employee,
this isn't going to help -
voice-port 0/0/0:15
compand-type u-law
ulaw coding is for North America ... I'm surprised you can used this system as the audio would be distorted with a companding mismatch. Try changing it back to 'compand-type a-law', and also add 'network-clock-select 1 e1 0/0/0' to sync the DSP's with the clocking coming in on the E1 interface.
What happens if you call a normal land line, not a cell phone ? Does it only happen with cell phones or with all outgoing calls?
