07-19-2008 09:51 AM - edited 03-06-2019 12:18 AM
Hi below i am enclosing basic view of my network.
I configured Nat Exemption in my ASA 5520
nat (inside) 0 172.20.0.0 255.255.0.0
route in ASA as
route outside 0.0.0.0 0.0.0.0 122.x.x.33 1
route inside 172.0.0.0 255.0.0.0 172.x.x.1 1
and configured PAT over my 2801 router inside interface where there is a route as follows
ip route 0.0.0.0 0.0.0.0 122.x.x.50
ip route 172.16.0.0 255.240.0.0 122.x.x.44
and my doubt is i want to configure PAT over my ASA 5520 and remove NAT in 2801 router how can i change the ROute commands in both ASA and Router
Please Help me in this regard
Solved! Go to Solution.
07-21-2008 07:25 AM
As far as i see, you do not need to change any route's commands.
however you may remove
as the firewall outside and router inside are directly connected, which consideration i made after reading the following statement "configured PAT over my 2801 router *inside* interface"
Keeping the route wouldn't cause any problem anyway.
Remember to Rate me if helpful.
07-19-2008 08:46 PM
On the 2801 router :-
remove the IP NAT statements and also remove
On the ASA box (to PAT with the outside interface IP): -
no nat (inside) 0 172.20.0.0 255.255.0.0
nat (inside) 10 172.20.0.0 255.255.0.0
global(outside) 10 interface
Hope this helps.
07-21-2008 07:25 AM
