Open only one port between Site to Site Tunnel
Answered Question
Jul 19th, 2008
Hi, I have just estlablished a Site to Site Tunnel between our office and ISP and exempt IP protocol between both end and its working fine, I can access the remote network and they can access my office network as well. Now I want that we access the remote network and access all ports as we are able to access but I dont want that remote site able to access my office network except only 25 port. Please advice. The access list is below mentioned:-
access-list outside_cryptomap_3 extended permit ip 192.168.50.0 255.255.255.0 host 172.17.80.247 255.255.255.0
access-list outside_cryptomap_3 extended permit ip 192.168.51.0 255.255.255.0 host 172.17.80.247 255.255.255.0
access-list inside_nat0_outbound extended permit ip 192.168.51.0 255.255.255.0 host 172.17.80.247 255.255.255.0
access-list DMZ_nat0_outbound extended permit ip 192.168.50.0 255.255.255.0 host 172.17.80.247 255.255.255.0
Office Inside Network 192.168.50.0/24
Office DMZ Network 192.168.51.0/24
Remote Network 172.17.80.247/24
I also need that I could able to ping remote network machines and servers from office network Inside and DMZ Zones.
Correct Answer by a.alekseev about 8 years 11 months ago
access-list XXX permit tcp 172.17.80.247 255.255.255.0 192.168.50.0 255.255.254.0 eq 25
group-policy x.x.x.x attributes
vpn-filter value XXX
Overall Rating: 5 (1 ratings)
a.alekseev Sat, 07/19/2008 - 13:02
  • Gold, 750 points or more
no sysopt connection permit-ipsec
access-list OUTSIDE-IN permit tcp 172.17.80.247 255.255.255.0 192.168.50.0 255.255.254.0 eq 25
access-group OUTSIDE-IN in int outside
or another variant
under "group-policy x.x.x.x attributes"
you can use "vpn-filter value ACL"
configure terminal
nikuhappy2010 Sat, 07/19/2008 - 13:09
If I use this command "no sysopt connection permit-ipsec" then my other tunnels will be stop.
Using for ISP Tunnel
tunnel-group 2.2.2.2 type ipsec-l2l
tunnel-group 2.2.2.2 ipsec-attributes
Can you post the commands one by one. Here I am bit confused. Thanks
Correct Answer
a.alekseev Sat, 07/19/2008 - 13:35
nikuhappy2010 Sat, 07/19/2008 - 13:51
Hi, we dont need to delete any command as I mentioned and second would like to understand that vpn-filter is a command in ASA.
a.alekseev Sat, 07/19/2008 - 13:58
if you want to understand :)
read the configuration guide.
vpn-filter
To specify the name of the ACL to use for VPN connections, use the vpn-filter command in group policy or username mode. To remove the ACL, including a null value created by issuing the vpn-filter none command, use the no form of this command. The no option allows inheritance of a value from another group policy. To prevent inheriting values, use the vpn-filter none command.
You configure ACLs to permit or deny various types of traffic for this user or group policy. You then use the vpn-filter command to apply those ACLs.
vpn-filter {value ACL name | none}
no vpn-filter
nikuhappy2010 Sat, 07/19/2008 - 14:02
Thanks, last I want to know that is there any other way to do the same process.
