Warning message
jamesl0112 Sun, 07/20/2008 - 01:15
  • Bronze, 100 points or more
In addition to login local, you will also need to specify privilege level 15 when configuring the VTY lines.
anitachoi3 Sun, 07/20/2008 - 08:51
Try following:
1. connect one PC to 192.168.32.0 segment. the IP address of PC is 192.168.32.10/24
2. launch IE
3. key in: https://192.168.32.2
You should get the login promopt.
BTW, pls check the 802.1q setting.
rdgs
ellendrew Sun, 07/20/2008 - 13:46
Make sure java is installed on your PC and ip http server is also enabled on your router.
