CCME NANP
Jul 19th, 2008
Hi, I am configuring a CCME 4.3 system to be installed in the States (New York). Is there any NANP for CCME that we need to install in CCME like in CCM? If not what configuration for external dialling should we configure in CCME? In the UK we just create dial peers with the command destination pattern 9T. Thanks, Chandrasen
Overall Rating: 5 (1 ratings)
Chad Stachowicz Sat, 07/19/2008 - 13:42
9T works here in the states aswell, but I try and bust out LD / LOCAL / INTL / 911 seperatly so I have more flexability in the future.
HTH,
Chad
cg100668 Sat, 07/19/2008 - 13:47
Hi Chad,
Thanks for the prompt reply. Do you have any example for the configuration for LD/LOCAL/INTL/911? I will try to configure as per your suggestion.
Chandrasen
Chad Stachowicz Sat, 07/19/2008 - 20:19
dial-peer voice 2401 pots
description *** Description US/Canada INTL***
preference 1
destination-pattern 9011T
port 0/0/1:23
prefix 011
dial-peer voice 2201 pots
description *** Description US/Canada LD ***
preference 1
destination-pattern 91[2-9]..[2-9]......
port 0/0/1:23
forward-digits 10
dial-peer voice 2213 pots
description *** Description US/Canada 10 Digit Local ***
preference 10
destination-pattern 9[2-9]..[2-9]......
port 2/1:23
forward-digits 10
dial-peer voice 2105 pots
description *** Description US/Canada Emergency ***
preference 5
destination-pattern 9911
port 0/2/1:23
forward-digits 3
dial-peer voice 2006 pots
preference 6
destination-pattern 911
port 0/3/0:23
forward-digits all
By using differnet dial-peers you can now control each type of call different once it gets to the gateway, its just good practice!
HTH, please rate useful posts!
Chad
cg100668 Sun, 07/20/2008 - 13:43
Hi Chad,
Thanks very much for the example above. I believe that the above represents all the dial peers we need to create for the CCME to call any number within US/Canada and the rest of the world. Last request from you, it is possible to send me a complete configuration for a CCME in the States including ISDN PRA configuration? As you know the ISDN PRA config is different here in UK compared to US.
Chandrasen
