Bonding T1 lines point to point connection (both data and VoIP)
Corey Davies
I'm in the process of creating a plan to bond a T1 line to our current T1 line (moving from 1.5 to 3.0 Mbps). Are there any special configuration issues on a Point to Point T1 circuit when used for both Voice and Data if no current QoS policy is in place? Both sides of the P2P connection will be using a Cisco 2621xm router with VWIC-2MFT-T1/E1 cards.
kerek
Level 4
Level 4
Are you using mppp or mfr.
In both case you may need to set the fragmenting if both data and voice is used in order to minimize the serialization delay.
Hope it helps, rate if does
Krisztian
