ASA 5510 -No route from PC in dmz via backup interface
janakamolagoda
Client has 2 ISP solution configured with Backup interface and all seems work fine except a PC in DMZ cannot access internet via Backup interface although it has NATs
global (backup) 2 202.A.B.C netmask 255.255.255.255
nat (DMZ1) 2 172.16.20.5 255.255.255.255
6 Replies 6
a.alekseev
Level 7
Level 7
how did you check it?
inside lan can access outside, but not DMZ.
What is your problem?
and show the configuration.
I mentioned in my first mail
In common case you can use your backup line only then you primary line goes down.
How is the routing setup? Do you realize ASA can have default routes going out of only one interface 'at once'?
Farrukh
