Abdulbaseer Mohammed Sun, 07/20/2008 - 05:30
You have few services not started properly. Check your RMCM settings, if you had every thing done right restarting resolves the problem most of the time.
sohaildxbfze Sun, 07/20/2008 - 08:13
restarting several times didnt solve the issue.
other default scripts work but not icd.aef.
to let it work rmcm should be in IN service state
any help????
