Vtp problem
Jul 20th, 2008
Hello, I am using packet tracer and if I design for example 3 switches and configure one switch as vtp server and domain X and the other 2 switches as vtp client and domain X, if I add a vlan on the switch configured as server the others are not getting the update when typing show vlan brief. It should be fairly easy or maybe I am missing something. Thank You
Overall Rating: 5 (1 ratings)
sundar.palaniappan Sun, 07/20/2008 - 07:02
  • Green, 3000 points or more
For VTP to work the switches need to be trunked to the VTP server switch. Moreover, the trunks should allow VLAN1 traffic to pass. Can you verify that part?
