Switch ports (layer-3) terminates Laser link flaps
Jul 20th, 2008
I have a Laser link between 2 buildings. The both ends of the link terminates on 4500 L3 switch ports.Both switches logs interface (both ends) flap atleast 3-4 times in a day, even when the Laser receival powers are good.
BGP is running acoss the link and once in 2-3 days the BGP takes few seconds hit. See below the switch port configs and suggest if you think anything need to be changed to avoid this. I do not see any major L1 errors to doubt on the cabling.
BLDGA-4510-S1#sh runn int gig 3/4
Building configuration...
Current configuration : 298 bytes
interface GigabitEthernet3/4
description :LOS/Laser link to BLDGB
no switchport
dampening 30 2000 200 20 restart
bandwidth 900000
ip address 10.40.2.1 255.255.255.252
logging event link-status
delay 15
keepalive 4
udld port aggressive
no cdp enable
end
BLDGB-4510-S1#sh run int gig 4/3
Current configuration : 283 bytes
interface GigabitEthernet4/3
description :LASER/LOS Link to BLDGA
no switchport
ip address 10.40.2.2 255.255.255.252
delay 15
keepalive 4
no cdp enable
end
Thank you
MS
lgijssel Mon, 07/21/2008 - 05:45
Hi MS,
Your interface config should be fine, the problem that you describe is unlikely to be caused by configuration issues.
A few thing came up when reading this:
1: Be aware that the laser's output level can also be too high which would be causing bit errors due to oversteered inputs. You could try to use a set of dampers to reduce the input levels.
2: Please check that the fiber cable is indeed single mode and is in accordance with the specs of the GBIC or SFP.
3: Verify that your fiber patchcables have the same specs as the fiber link.
regards,
Leo
