Receive Call after commercial schedule
Jul 20th, 2008
Hi Guys,
Hi have the following problem:
Our Customer have a solution of Telephony IP with CallManager version 5.1 and the Project was did of way: Each user have a two branches: a branch false that only make calls for the sites and branch true that can do any calls when the user logon using the Extension Mobility. We have the solved the bellow problem: The trunk number is 3572-0100 that only work when the secretary use the Extension Mobility between 7:00 am to 7:00 pm. Our Customer need that this number work when the trunk number is logoff after 7:00 pm when the secretary go out. It's possible?
Thank You,
