darpotter Mon, 07/21/2008 - 05:47
  • Silver, 250 points or more
Hi Lahki
ACS holds users in its internal database (pre v4 and in a SQL Anywhere DB post v4)
The data isnt human readable, so you need something like extraxi aaa-reports! which can import the database (csutil dump file or cssupport package cab)
Once imported you'll be able to report on the users, last authentication date, account status etc.
http://www.extraxi.com?utm_source=technet&utm_medium=forum
Lucky8888 Mon, 07/21/2008 - 17:23
Thanks for your response. extraxi aaa-reports is excellent for auditing, monitoring, troubleshooting, and etc. But Its not what we need at this stage.
Maybe I did not make myself clear. We have a third application which needs the live authenticated information to grant access to the authenticated users.
Is there anyway to achieve this with ACS40?
Lahki
Jagdeep Gambhir Tue, 07/22/2008 - 05:22
  • Red, 2250 points or more
Lahki,
I don't think that is possible. The only readable source to know the list of authenticated user are passed authentication logs/ logged in user report / Accounting report.
Other then this there is no way to get the information you are looking for.
Hope that helps !
~JG
Do rate helpful posts
