Edison Ortiz Sun, 07/20/2008 - 20:02
  • Hall of Fame,
    Founding Member
Let's take this ACL as an example:
R2#sh ip access-lists
Extended IP access list 101
10 permit ip host 1.1.1.1 host 2.2.2.2
20 permit ip host 1.1.1.1 host 3.3.3.3
30 permit ip host 1.1.1.1 host 4.4.4.4
You noticed how the output has a number from 10 to 30 on each ACE?
Now, let's say I want to knock out line number 20.
R2(config)#ip access-list extended 101
R2(config-ext-nacl)#no 20 permit ip host 1.1.1.1 host 3.3.3.3
R2(config-ext-nacl)#end
HTH,
__
Edison.
Please rate helpful posts
jamesl0112 Mon, 07/21/2008 - 00:06
  • Bronze, 100 points or more
Edison,
That's pretty handy - I didn't know you could edit a numbered ACL as if it was a named ACL.
Marwan ALshawi Sun, 07/20/2008 - 20:04
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
When you edit an ACL, it requires special attention. For example, if you intend to delete a specific line from a numbered ACL that exists as shown here, the entire ACL is deleted
http://www.cisco.com/en/US/products/sw/secursw/ps1018/products_tech_note09186a00800a5b9a.shtml#editacls
Rate if helpful
gojericho0 Mon, 07/21/2008 - 07:16
Also, i believe you need at least version 12.3 of the IOS in order to delete numbered access-lists line by line
AJAZ NAWAZ Mon, 07/21/2008 - 08:47
  • Silver, 250 points or more
just tested on 65k with 12.2 - all good. I suspect this method has been available for longtime, it's just been hidden (not to be confused with 'hidden' commands).
Ajaz
yee.lay.yo Mon, 07/21/2008 - 18:07
Hi Edison,
The problem fix by your instruction.
Thanks a lot.
