IP Change Outage
Jul 20th, 2008
I'm looking for a procedure to minimize the outage of changing the "inside" NIC IP of active/standby ASA. Can someone give me some hinters?
I would schedule a down time slot of about oooooh 5 seconds (depending no your nearest layer 3 device), attach my console cable to the back of the primary - configure on your inside interface the command:-
ip address x.x.x.x y.y.y.y standby z.z.z.z
(also depending on your failover config/requirements)
As long as your/if you are using it:-
failover link failover <>
failover interface ip failover <> <> standby <>
does not change - can't see an issue!
Oooo and wr mem - to sync the configs of course!
