Disabling hook-flash for fxo
Jul 20th, 2008
In this case I observe
Analog telephone (on ata) is in hold state and the fxo port (previously ata makes ouside call) is open for a long time.
I think, analog telephone makes on-hook
but fxo understand this hook-flash.
I set hook-flash timeout 150 ms under fxo
timing hookflash-out 150
This problem occurs rarely
I want to disable hook-flash, how?
vkapoor5 Fri, 07/25/2008 - 06:23
In Call Manager Admin under the "service --> service parameters --> [CCM server] --> Cisco CallManager" menu there is a parameter called "Flash Hook Duration (msec)" parameter. The default value is 500ms. You can not disable the hook flash detection. But you can configure the detection timing by setting the SigTimer parameter.
