guruprasadr Sun, 07/20/2008 - 21:14
  • Gold, 750 points or more
HI Philip, [Pls RATE if HELPS]
To define the conditions for redistributing routes from one routing protocol into another, or to enable policy routing, use the route-map command in global configuration mode and the match and set command in route-map configuration modes. To delete an entry, use the no form of this command.
route-map map-tag [permit | deny] [sequence-number]
no route-map map-tag [permit | deny] [sequence-number]
Examples
The following example redistributes Routing Information Protocol (RIP) routes with a hop count equal to 1 into Open Shortest Path First (OSPF). These routes will be redistributed into OSPF as external link-state advertisements (LSAs) with a metric of 5, metric type of Type 1, and a tag equal to 1.
router ospf 109
redistribute rip route-map rip-to-ospf
route-map rip-to-ospf permit
match metric 1
set metric 5
set metric-type type1
set tag 1
Hope I am Informative.
PLS RATE if HELPS
Best Regards,
Guru Prasad R
