server side source NAT
Answered Question
Jul 20th, 2008
Hello!
The below simple config is not working.
We would like to change the server source IP in the server initiated connection.
The access-list state is NOT-ACTIVE.
Why ? Any help would be appreciated !
class-map match-any NAT_CLASS
2 match access-list NAT_ACCESS
policy-map multi-match NAT_POLICY
class NAT_CLASS
nat dynamic 1 vlan 87
interface vlan 73
description ACE-Application
ip address 192.168.29.18 255.255.255.248
alias 192.168.29.22 255.255.255.248
peer ip address 192.168.29.20 255.255.255.248
access-group input ALL
access-group output ALL
nat-pool 1 10.42.16.30 10.42.16.30 netmask 255.255.255.0 pat
no shutdown
interface vlan 87
ip address 192.168.13.86 255.255.255.248
service-policy input NAT_POLICY
no shutdown
access-list NAT_ACCESS line 1 extended permit tcp host 192.168.13.81 any eq telnet
access-list NAT_ACCESS line 30 extended permit icmp any any
Admin# sho access-list NAT_ACCESS
access-list:NAT_ACCESS, elements: 2, status: NOT-ACTIVE
remark :
Correct Answer by Syed Iftekhar Ahmed about 8 years 9 months ago
Make the following change
class NAT_CLASS
nat dynamic 1 vlan 73
Syed Iftekhar Ahmed
Overall Rating: 5 (1 ratings)
Correct Answer
Syed Iftekhar Ahmed Sun, 07/20/2008 - 23:59
  • Blue, 1500 points or more
class NAT_CLASS
Syed Iftekhar Ahmed
KAROLY KOHEGYI Mon, 07/21/2008 - 00:10
Hi!
I overlooked.
Situation changed a little.
Status : ACTIVE
Interface: vlan 87
service-policy: NAT_POLICY
class: NAT_CLASS
nat:
curr conns : 1 , hit count : 3
dropped conns : 0
client pkt count : 59 , client byte count: 2754
server pkt count : 56 , server byte count: 3324
conn-rate-limit : 0 , drop-count : 0
bandwidth-rate-limit : 0 , drop-count : 0
Lajos-ACE/Admin# sho access-list NAT_ACCESS
remark :
The policu is working but the accesslist is not.
The NAT is not working also.
KAROLY KOHEGYI Mon, 07/21/2008 - 00:16
Hi!
I overlooked.
Status : ACTIVE
Interface: vlan 87
class: NAT_CLASS
nat:
dropped conns : 0
remark :
Syed Iftekhar Ahmed Mon, 07/21/2008 - 00:25
Access-list "NOT-ACTIVE " means that it is not applied to an interface. Which is normal for ACLs that are only used in class maps.
Is the traffic for NAT is covered by the ACL (ACL applied to the interfaces) to allow the traffic through the ACE?
Syed Iftekhar Ahmed
KAROLY KOHEGYI Mon, 07/21/2008 - 00:34
Hi!
Yes. I use the ALL access-list on the interfaces.
Lajos-ACE/Admin# sho access-list ALL
access-list:ALL, elements: 2, status: ACTIVE
remark :
access-list ALL line 10 extended permit ip any any (hitcount=19682682)
access-list ALL line 20 extended permit icmp any any (hitcount=0)
I make a telnet connection from 192.168.13.81 to outside device.
the connection is made but the source IP is 192.168.16.81 instead of 10.42.16.30.
Syed Iftekhar Ahmed Mon, 07/21/2008 - 01:13
Your config looks ok.
Are you sure the server initiated connection is not bypassing ACE? Do you see this conn on ACE (sh conn)?
Just for testing remove ACL from the class-map ,Instead use source-address
2 match source 192.168.13.81 255.255.255.255
Syed
