Creating a VRF
Jul 21st, 2008
I need to create a VRF on a Bastion router for management..can someone direct on how I should proceed? I have a physical connection to the Bastion switch and I am not sure how I should proceed with a VRF to only allow the management vlan to be seen..
greatly appreciate the help
Overall Rating: 5 (1 ratings)
dhananjoy chowdhury Mon, 07/21/2008 - 05:23
  • Silver, 250 points or more
Suppose the router interfaces are
f0/0 - Connecting to Internet - 20.0.0.1/24
f0/1 - insideLAN - 10.0.0.1/24
f0/2 - Management - 172.16.20.1/24
your PC - 172.16.20.2
For the Management just configure the int f0/2 with ip 172.16.20.1 and your PC should be connected to this port for Management.
( If you are using switch , create a seperate VLAN for accomodating Router f0/ 2 and your PC)
then create a VRF VR1 and allocate the interfaces f0/0 and f0/1
Router(config)#ip vrf VR1
Router(config-vrf)#rd 100:100
Router(config)#int f0/0
Router(config-if)#no shut
Router(config-if)#ip vrf forwarding VR1
Router(config-if)#ip add 20.0.0.1 255.255.255.0
Router(config)#int f0/1
Router(config-if)#ip add 10.0.0.1 255.255.255.0
Routing :
Default route towards ISP GW
Router(config)#ip route vrf VR1 0.0.0.0 0.0.0.0
Hope this helps.
ud0508500 Mon, 07/21/2008 - 05:37
this is excellent!!! I'll give it a try..thank you very much
