Voice IP scheme, Planning
Jul 21st, 2008
Need an advice in IP-designing for voice infrastructure, Communications Manager, Unity.
The point of view is a VLAN/IP subnet assignments that must be accomplished.
There are two campuses (the same LAN): the first contains PUB with Unity and voice
gateway. Another - only subscriber. Wish to assign /28 per campus for voice subnet
(I do not include IP Phones in there cause they live in another vlans on the access layer).
Any recommendation or advice due to the abovementioned IP design ?
May be I should change something in my IP planning ?
Justin Brenton Mon, 07/21/2008 - 22:08
Sounds like your on the right track.
I would design 1 voice vlan and 1 data vlan. Route between vlans with intervlan routing.
To give you a more accurate suggestion we would need more information. How many user's per site? topology diagrams? How are the 2 campuses connected to each other?
HTH, Please rate if so
Justin
