Local Gateways for outgoing calls(Dial plan config)
Jul 21st, 2008
My customer has two site site A & site B connected by WAN.Each site has two local voice gateways to PSTN.
Both site users make local and IDD PSTN calls to same numbers(Route patterns).
How is possible to configure the CCM , so that the outgoing calls at each site use the local site voice gateways.
Overall Rating: 4 (1 ratings)
Chris Deren Mon, 07/21/2008 - 05:02
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Each site has to be configured with it's own Calling Search Spaces assigned to the phones with access to paritions assigned to local route patterns that point to local route litst --> route groups --> gateways.
Chris
ra_jeshkalra_2 Mon, 07/21/2008 - 06:17
But for both the sites, the route patterns to be dialed out the same (idd & local), both the sites are in same country.
Bilieve CSS & partions are for restrictions(COS).
Chris Deren Mon, 07/21/2008 - 06:23
  • Hall of Fame,
CSS/Paritions are not just restrictions, they control route access, and in CM 6.X and below this is the only way to control where calls are routed. You need to do as I said earlier, create new CSS/paritions for this new location, duplicate Route Patterns/Route Lists/Route Groups.
Chris
