Shell Command Auth Question
michael.leblanc Mon, 07/21/2008 - 07:52
  • Silver, 250 points or more
I'm assuming you are using CSACS (not indicated) for defining your command sets.
e.g.:
"Deny" radio button selected (i.e.: only listed commands will be authorized).
Command List:
clear
disable
enable
show
"Clear" command argument(s) set as follows:
(a) Deselect the "Permit Unmatched Args" checkbox.
(b) Enter the following argument(s) into the list:
permit counters
... or, to be more specific:
permit counters Ethernet 0
permit counters FastEthernet 0
This should result in the ability to clear all counters, or the counters of specific interfaces (if you define them).
Notes:
(1) Command arguments are case sensitive and may differ from how they are entered at the CLI.
(2) A sniffer is helpful in determining proper case.
(3) Wireshark is capable of decrypting TACACS+ packets if you configure the application with the password.
dhananjoy chowdhury Mon, 07/21/2008 - 08:51
I had mentioned it for the command line.
If suppose you have local users with Privelege level 2 and 15, then
username admin2 privilege 2 password cisco
username admin15 privilege 15 password cisco
privelege exex level 2 ping
privilege exec level 2 clear counter
privelege exec level 15 telnet
privelege exec level 15 show config
privelege exec level 15 show logging
Yes, I'm using CACS, sorry for not specifying.
So if i put "clear" in as the command and then put: "permit counters FastEthernet 0" will that allow all fa0/1 - x interfaces or do I have to put them in individually? I'm really looking for a way to allow it on all fa and gi interfaces if possible but w/o putting each interface into acs.
michael.leblanc Mon, 07/21/2008 - 12:56
If you are willing to permit the clearing of counters for "all" interface types (do a "clear counters ?", to see the list), use:
permit counters
If you only want to permit all FastEthernet and GigabitEthernet interfaces, use:
permit counters GigabitEthernet
The inclusion of "FastEthernet 0" in my previously posted example was for a specific interface, where "FastEthernet 0" was a complete interface name (on a different platform), and was not intended to specify FastEthernet 0/1 - x.
Edit: If you want to control specific interfaces, make sure to use the appropriate white-space in your command set argument definitions.
E.g.: permit counters FastEthernet 0 1
The "FastEthernet", "0", and "1", are all separate arguments.
