LDAP question.
Jul 21st, 2008
Hi All,
We have CallManager 4.2(3). Also, We recently installed a 3rd party call monitoring software (CallRex) at one paricular section in our organization.
Now, the tech people from Callrex want to access the LDAP part in CallManager in order to complete installation. I have no idea where to look it up or what kind of passwords it uses.
Can anyone please shed more light on this? Will rare useful posts. Thanks in advance.
Overall Rating: 4 (1 ratings)
Jaime Valencia Mon, 07/21/2008 - 06:30
open this file:
this is the one that contains that info, pwd by default should be ciscocisco
it's the same user and password you use to log into DCD
if this helps, please rate
Naveen Raj Janardhan Mon, 07/21/2008 - 06:31
I guess I figured out what I wanted. Well, this is what I did:
I downloded the LDAP browser software from the internet. Then, I put in the IP address of the Publisher in the hostname field. and then the DC directory password ( was previously not aware that DC directory actually meant LDAP). Changed the default port number from 389 to 8404 (very crucial step). Finally pressed OK button and everything else worked like magic!!
Jaime Valencia Mon, 07/21/2008 - 08:58
well, LDAP is a protocol used to access directories not the actual directory.
we use LDAP to access DCD, AD or any directory you're integrated with to access the information.
in any case, good to hear you were able to got the info =)
