Slow pings over different vlan subnets
Jul 21st, 2008
Okay, so I have a 3640 router with a fast ethernet port on it. And I also have a 2950 switch set up with several different vlans that are trunked through one port to the 3640 fast ethernet port.
Now the problem I'm having is that since I put the router and switch in, I've been getting a huge delay in ping time. Not so much the milliseconds (about 4 ms average), but when I start the ping, it just kinda idles there for 5-10 seconds and then starts showing the ping data.
even computers on the same subnet in this setup do the same thing. I get no such delay when I type in the actual ip address, but only with the host names.
Here are my configs:
ROUTER
Using 1541 out of 129016 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname rtmw-em-test
enable secret 5 ####
enable password ###
ip subnet-zero
ip cef
ip domain-name ###.com
ip name-server 10.99.6.100
interface Ethernet0/0
no ip address
shutdown
half-duplex
interface Serial0/0
no ip address
shutdown
interface Serial0/1
no ip address
shutdown
interface FastEthernet1/0
no ip address
speed auto
full-duplex
no mop enabled
interface FastEthernet1/0.1
encapsulation dot1Q 1 native
ip address 10.99.6.254 255.255.255.0
interface FastEthernet1/0.2
encapsulation dot1Q 178
ip address 10.100.178.254 255.255.255.0
interface FastEthernet1/0.3
encapsulation dot1Q 191
ip address 10.100.191.254 255.255.255.0
interface FastEthernet1/0.4
encapsulation dot1Q 210
ip address 10.100.210.254 255.255.255.0
interface FastEthernet1/0.5
encapsulation dot1Q 189
ip address 10.100.189.254 255.255.255.0
interface Serial2/0
no ip address
shutdown
serial restart-delay 0
ip classless
no ip http server
snmp-server community public RO
snmp-server enable traps tty
line con 0
line aux 0
line vty 0 4
password ###
login
end
adambrandes Mon, 07/21/2008 - 05:51
SWITCH
Using 3031 out of 32768 bytes
version 12.1
no service pad
hostname swtmw-em-test
enable secret 5 ###
enable password ###
ip subnet-zero
vtp domain ###
vtp mode transparent
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
spanning-tree uplinkfast
vlan 178,189,191,210
interface FastEthernet0/1
switchport access vlan 178
no snmp trap link-status
spanning-tree portfast
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
switchport access vlan 191
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
switchport access vlan 210
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
switchport access vlan 189
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
switchport mode trunk
interface FastEthernet0/25
interface FastEthernet0/26
interface Vlan1
ip address 10.99.6.253 255.255.255.0
no ip route-cache
ip default-gateway 10.99.6.254
ip http server
line con 0
line vty 0 4
password ####
login
line vty 5 15
password ####
login
end
bs6825 Mon, 07/21/2008 - 13:07
If the problem only occurs when using DNS, that would be the first thing I would look at. Ensure that pings to your DNS server are good by IP and test the DNS server response by doing some nslookups from a workstation.
