3550 not loading IOS image
Hello folks I need some help. I came in this morning and my 3550 is in switch: prompt. I tried to issue boot command and point it to "flash:c3550-ipservices-mz.122-25.SEB4/c3550-ipservices-mz.122-25.SEB4.bin" but the image doesn't load.
Here's the out put....
switch: boot flash:c3550-ipservices-mz.122-25.SEB4/c3550-ipservices-mz.122-25.SEB4.bin
Loading "flash:c3550-ipservices-mz.122-25.SEB4/c3550-ipservices-mz.122-25.SEB4.bin"...flash:c3550-ipservices-mz.122-25.SEB4/c3550-ipservices-mz.122-25.SEB4.bin: short read: bad mzip file
Error loading "flash:c3550-ipservices-mz.122-25.SEB4/c3550-ipservices-mz.122-25.SEB4.bin"
Interrupt within 5 seconds to abort boot process.
Boot process failed...
switch:
Here's the environment variables & the flash...
switch: set
BOOT=flash:c3550-ipservices-mz.122-25.SEB4/c3550-ipservices-mz.122-25.SEB4.bin
MAC_ADDR=00:0D:65:99:8B:00
MODEL_NUM=WS-C3550-24PWR-EMI
MODEL_REVISION_NUM=D0
MOTHERBOARD_ASSEMBLY_NUM=73-8100-09
MOTHERBOARD_REVISION_NUM=A0
MOTHERBOARD_SERIAL_NUM=CAT07280VPU
POWER_SUPPLY_PART_NUM=341-0029-02
POWER_SUPPLY_SERIAL_NUM=DTH1020DEFF
SYSTEM_SERIAL_NUM=CAT0729Z0VR
switch: dri flash:
Unknown cmd: dri
switch: dir flash:
Directory of flash:/
2 -rwx 275 <date> info
3 drwx 128 <date> c3550-ipservices-mz.122-25.SEB4
354 -rwx 275 <date> info.ver
356 -rwx 0 <date> env_vars
357 -rwx 676 <date> vlan.dat
358 drwx 64 <date> lost+found
359 -rwx 2093 <date> base-config
360 -rwx 2093 <date> config.text
361 -rwx 5 <date> private-config.text
362 -rwx 356 <date> system_env_vars
15179776 bytes available (819200 bytes used)
I need some guidance on how to resolve this issue, any help is highly appreciated.
JP
