Cisco 3750 & Radius Authorization
Jul 21st, 2008
I have some difficulties to implement AAA.
I'm trying to configure our cisco in a way to authenticate and authorize users, using our Radius server.
After authentication, this server should send an attribute to define the user privilege.
Here what I did:
username 1geob301
radius-server host 172.15.2.21 auth-port 1812 acct-port 1813 key Secret
radius-server source-ports 1645-1646
radius-server vsa send authentication
aaa new-model
aaa authentication login test-list group radius
aaa authorization exec test-list group radius
On the radius server, once the user is authenticated, the server send the attribute cisco-avpair = "shell:priv-lvl=15"
The authentication works. But I'm failing to configure correctly the authorization.
Here the debug trace:
01:40:38: AAA: parse name=tty1 idb type=-1 tty=-1
01:40:38: AAA: name=tty1 flags=0x11 type=5 shelf=0 slot=0 adapter=0 port=1 channel=0
01:40:38: AAA/MEMORY: create_user (0x3B91F78) user='NULL' ruser='NULL' ds0=0 port='tty1' rem_addr='172.16.30.68' authen_type=ASCII service=LOGIN priv=1 initial_task_id='0', vrf= (id=0)
01:40:38: AAA/AUTHEN/START (3767632247): port='tty1' list='test-list' action=LOGIN service=LOGIN
01:40:38: AAA/AUTHEN/START (3767632247): found list test-list
01:40:38: AAA/AUTHEN/START (3767632247): Method=radius (radius)
01:40:38: AAA/AUTHEN (3767632247): status = GETPASS
01:40:38: AAA/AUTHEN/CONT (3767632247): continue_login (user='1geob301')
01:40:38: AAA/AUTHEN (3767632247): Method=radius (radius)
01:40:39: AAA/AUTHEN (3767632247): status = PASS
01:40:39: tty1 AAA/AUTHOR/EXEC (2157384509): Port='tty1' list='test-list' service=EXEC
01:40:39: AAA/AUTHOR/EXEC: tty1 (2157384509) user='1geob301'
01:40:39: tty1 AAA/AUTHOR/EXEC (2157384509): send AV service=shell
01:40:39: tty1 AAA/AUTHOR/EXEC (2157384509): send AV cmd*
01:40:39: tty1 AAA/AUTHOR/EXEC (2157384509): found list "test-list"
01:40:39: tty1 AAA/AUTHOR/EXEC (2157384509): Method=radius (radius)
01:40:39: AAA/AUTHOR (2157384509): Post authorization status = FAIL
01:40:39: AAA/AUTHOR/EXEC: Authorization FAILED
Could you help me please ?
Bruno
michael.leblanc Mon, 07/21/2008 - 16:55
Are you deliberately choosing not to do enable authentication via the RADIUS server?
I think your issue may have to do with the way you have configured the user profile on the RADIUS server.
With our configuration we do not see cisco-avpair = "shell:priv-lvl=15" being passed to the AAA client.
We see the IETF RADIUS Attribute 006 Service-Type being passed to the AAA client, with a value of "login-User" or "Administrative-User" depending on how we choose to configure the user profile.
If the user profile is set to "Login-User", the user will be prompted for the enable password after successfully providing the user password. An additional user profile will be required for user "$enab15$". The "$enab15$" user profile would not be configured to pass IETF RADIUS Attribute 006 Service-Type to the AAA client.
If the user profile is set to "Administrative-User", the user will proceed to enable mode after having provided the user password, without being prompted for the enable password.
bruno.geoffron Mon, 08/11/2008 - 01:12
Thanks for your answer.
I found the solution, it was simply a mistake in my radius configuration.
Here the attribute i send after authentication:
Service-Type = NAS-Prompt-User
Here my cisco configuration:
aaa new-model
line vty 0
login authentication test-list
And it's working fine.
