PIX515 Limit on number of Tunnels?
Answered Question
Jul 21st, 2008
Hi all,
Is there a limit to the number of VPN tunnels that you can create on a Pix515?
Thanks for any help
MG
There is limit on the number of VPN peers, which is the same thing really. Check your license features by issuing the below as the cli:-
show ver - you should see something like:-
Licensed features for this platform:
Maximum Physical Interfaces : 3
Maximum VLANs : 10
Inside Hosts : Unlimited
Failover : Disabled
VPN-DES : Enabled
VPN-3DES-AES : Enabled
Cut-through Proxy : Enabled
Guards : Enabled
URL Filtering : Enabled
Security Contexts : 0
GTP/GPRS : Disabled
VPN Peers : Unlimited
The VPN peers is what you are looking for - numbered or unlimited! There is an encryption thru-put limitation you can't have a million tunnels and expect to get Mbs of thru-put!
HTH.
Overall Rating: 5 (1 ratings)
Correct Answer
Maximum VLANs : 10
Failover : Disabled
VPN-DES : Enabled
Guards : Enabled
GTP/GPRS : Disabled
HTH.
