Multiple VLANs on c1200
Jul 21st, 2008
I've configured 2 VLANs on cisco 1200 AP. One native (vlan 1) and tagged with vlan 2 tag. I created DHCP pool and i don't get IP address for encapsulated VLAN while i do for native.
My configuration:
Building configuration...
Current configuration : 2255 bytes
version 12.3
no service pad
service password-encryption
hostname ap
enable secret xxx
ip subnet-zero
ip dhcp excluded-address 10.60.129.1 10.60.129.60
ip dhcp excluded-address 192.168.1.1 192.168.1.2
ip dhcp pool dhcp-pool
network 10.60.129.0 255.255.255.0
default-router 10.60.129.1
ip dhcp pool mngmt
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
aaa new-model
aaa session-id common
dot11 ssid WHEP1a
vlan 1
authentication open
dot11 ssid mngmt
vlan 2
authentication open
username Cisco password xxx
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption key 1 size 40bit xxxtransmit-key
ssid WHEP1a
ssid mngmt
speed basic-1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2412
station-role root ap-only
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.2
encapsulation dot1Q 2
no ip route-cache
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
bridge-group 2 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.1
no ip route-cache
bridge-group 1
interface FastEthernet0.2
no ip route-cache
bridge-group 2
interface BVI1
ip address 10.60.129.55 255.255.255.0
no ip route-cache
interface BVI2
ip address 192.168.1.2 255.255.255.0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
control-plane
bridge 1 route ip
line con 0
line vty 0 4
end
IOS running is: C1200-K9W7-M,Version 12.3(8)JEB
Any suggestions?
Tnx for any help.
aamercado Sat, 12/20/2008 - 10:07
  • Bronze, 100 points or more
I'm having a similar issue - how did you fix this problem? thx
scottmac Sat, 12/20/2008 - 11:36
  • Green, 3000 points or more
The AP only supports services for a single scope for DHCP, and only for the native VLAN.
For more than that you need to set up a separate server.
Good Luck
Scott
aamercado Sun, 12/21/2008 - 17:23
Scott
When I search the netpro wireless forum, there are other folks who have a inside admin vlan/ssid and a guest vlan/ssid that "seem" to have fix this dhcp problem.
If it is only on native vlan, what is the purpose of multiple ssid/vlan/bridge-groups configs on the AP while the upstream switch is setup as a trunk port?
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
