Configure static ip routes on CS ACS-SE
Answered Question
Jul 21st, 2008
Hi!
We use a Cisco Secure ACS Solution Engine, running V4.2.0.124.3.
The Appliance hast two Ethernet Ports.
- We need to know how to configure an IP-Adress on the second port. But more:
- We need to know how to configure static IP-routes on this device.
Is anyone out there to tell us how to do it ?
Regards, Markus
Correct Answer by Jagdeep Gambhir about 8 years 10 months ago
Markus,
In acs you can only use one NIC and there is no way you can set static routes on it.
Your Cisco 1113 system has two integrated 10/100/1000-megabit-per-second (Mbps) Ethernet connectors. ACS SE supports the operation of either Ethernet connector, but not both connectors. Each Ethernet connector provides all the functions of a network expansion card and supports the 10BASE-T, 100BASE-TX, and 1000BASE-TX Ethernet standards.
Each NIC is configured to automatically detect the speed and duplex mode of the network.
~JG
Do rate helpful posts
Overall Rating: 5 (1 ratings)
Correct Answer
Jagdeep Gambhir Mon, 07/21/2008 - 09:32
  • Red, 2250 points or more
Markus,
~JG
