Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1926457members
1238324discussions
Community Activity
How can I communicate with Delta? 24 Hours Customer Service
헗헲헹혁헮 헔헶헿헹헶헻헲's phone number to call and talk with a live 헿헲헽헿헲혀헲헻혁헮혁헶혃헲 fast is ퟏ-ퟖퟖퟖ-ퟖퟐퟗ-ퟏퟏퟕퟎ // ퟏ-ퟖퟖퟖ-ퟖퟐퟗ-ퟏퟏퟕퟎ. Select your connection language upon call and choose the IVR option that best suits your query by looking through the ones that are gen...
pocmon by Level 1
  • 1 Views
  • 0 replies
What is the most effective way to complain to 𝗗elta?
pocmon by Level 1
  • 1 Views
  • 0 replies
How can I communicate with Delta??24*7
pocmon by Level 1
  • 1 Views
  • 0 replies
How can I actually communicate with 𝗗elta 𝗔irlines?
pocmon by Level 1
  • 1 Views
  • 0 replies
L2VPN Over GRE
Hi I'm trying to extended a L2 segment using MPLS L2vpn over GRE. I am able to establish the tunnel and get ospf and mpls adjacency also the xconnect between the peer is up but my 2 test pc cant reach each other. This is my PE3 config.interface Gigab...
Resolved! packet tracer "Server Reset Connection" error
Hello.I'm working on a simple project and I have encountered an error where I cant access the HTTPS server via any terminal on the network. Any other post I have seen on the subject were either not relevant or I lacked sufficient knowledge to underst...
jenia69 by Level 1
  • 18313 Views
  • 7 replies
  • 1 Helpful votes
WebEx Audio not working on CarPlay
a. I initiate a WebEx call on my phone (through WebEx App).  Audio is working fine.  I then plug in the USBc cable into my phone, CarPlay comes up on the car display.  I see the call UI on the car display, but no audiob. I initiate a WebEx call from ...
bnsrini by Level 1
  • 264 Views
  • 5 replies
Umbrella Redundancy for AD Connector
What is best practice when it comes to AD connector(s)?If we were to have TWO AD connectors, is there a way to have it only fail over to the other connector if the active one went down? Rather than adding an additional connector on a separate server ...
bnuxoll by Level 1
  • 25 Views
  • 0 replies
Unable to get console access on switch 3850 - Blank terminal
Hello,I have a switch I am unable get a prompt on the console port.I can SSH to it, and have confirmed that the baud rate and stop bits are correct from the console switch. There are two other switches that I can console to.The differences are that t...
mrjelly by Level 1
  • 104 Views
  • 7 replies
GD Secter'a vIPer phone
I am unable to get a sectera viper phone to register with call manager. I have it built as a common 7960 sccp phone profile. When it boots up it will pull an IP address but will not register. This is my first time working with one of these phones and...
helmkamp01 by Level 1
  • 6994 Views
  • 10 replies
Using the second port ATA 192 (Webex Calling)
How do you configure the second port on the ATA 192? I set up the first port using the flow: Add workspace, add device, add number. But now when i try to configure the second port, i am only given the choice to pick from existing users!
