2 4948's, 2 Routed Links and 1 Trunk
Answered Question
Jul 21st, 2008
All,
I have two (2) catalyst 4948's that I am trying to get to talk to each via a trunk and I also have 1 routed interface on each switch. I have one routed interface per switch and between them I have a L2 trunk. What I want is if a PC is connected to switch 1 and has to go to switch 2 I don't want it to take the routed interface out on switch 1 and come back in on switch 2. I want local traffic to flow between the switches via the trunk. The only problem is, it isn't working. I have routes on both switches but I can't talk between the switches over the trunk. Can someone shed some light on this. Thanks.
Correct Answer by ralphcarter about 8 years 10 months ago
If your using VTP, use vtp version 2.
Do this on both switches. This will set them as both servers.
# vtp mode server
# vtp version 2
# vtp domain xxx
# vtp password mypassword
# vtp pruning
"show vlan brief" should show vlan 41 on both switches.
Overall Rating: 5 (1 ratings)
ralphcarter Mon, 07/21/2008 - 12:29
Can you post configs?
Keep in mind a trunk carries vlans, which are layer 2.
mrashby Mon, 07/21/2008 - 13:32
okay notice below the configs on sw2 and sw1. There is a routed interface on each switch and the other remaining interfaces are layer 2 trunks. I want local traffic to run between the trunks and traffic destined for the outside to just go out the routed interface. Is this possible the way I have it set up? Or should I just put both routed interfaces on one switch and keep the trunk?
SW2
no aaa new-model
ip subnet-zero
no ip domain-lookup
ip domain-name NET.SBA.GOV
no ip bootp server
cluster run
power redundancy-mode redundant
spanning-tree mode pvst
vlan internal allocation policy ascending
interface GigabitEthernet1/1
switchport access vlan 41
switchport port-security maximum 3
switchport port-security aging time 15
interface TenGigabitEthernet1/49
description Trunk to switch1
interface TenGigabitEthernet1/50
description Uplink to Dist 2
no switchport
ip address 165.110.17.153 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip hello-interval eigrp 1 1
carrier-delay msec 0
interface Vlan1
no ip address
shutdown
interface Vlan41
ip address 0.0.41.254 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
router eigrp 1
network 0.0.17.152 0.0.0.3
eigrp stub connected summary
no auto-summary
passive-interface default
no passive-interface TenGigabitEthernet1/50
redistribute connected
SW1
no aaa new-model
ip subnet-zero
ip cef load-sharing algorithm original
cluster run
ip ssh version 2
spanning-tree portfast
no switchport
ip address 0.0.17.97 255.255.255.252
switchport trunk allowed vlan 41
switchport mode trunk
interface Vlan1
no ip address
interface Vlan41
ip address 0.0.41.253 255.255.255.0
router eigrp 1
network 0.0.17.96 0.0.0.3
no auto-summary
no passive-interface TenGigabitEthernet1/49
ralphcarter Mon, 07/21/2008 - 17:12
Your trunk on switch2 is not configured.
on sw2 add this.
This way if PC1 sitting on sw1 port g1/1 wants to send traffic to PC2 sitting on sw2 port g1/1, it will use the trunk. PC1 will arp for PC2 mac address since it will be on the same subnet and the switch will feed it over the trunk.
mrashby Tue, 07/22/2008 - 05:31
Okay, thanks I got my trunks set. Now I need my vlans set I am running VTP v1 but still am not seeing vlan 41 on both switches. Can you shed some light on this?
Correct Answer
ralphcarter Tue, 07/22/2008 - 09:36
# vtp mode server
# vtp version 2
# vtp domain xxx
# vtp pruning
