C2955 Console Authorization Failed
Jul 21st, 2008
I have a client that has a WS-C2955T-12 switch he cannot access. When plugging into the console port, with known good console cable and settings in SecureCRT, I get an "% Authorization Failed". I hit enter and it gets the same error. The switch never gives me a chance to login. Can someone help either (a) with a reset to factory default w/o access or (b) password recovery on a WS-C2955T-12? Thanks in advance.
Ross Rehart Mon, 07/21/2008 - 12:21
Yea - I looked at that. There is no "Mode" button on the 2955.
AlessandroGuarda Tue, 03/04/2014 - 05:49
I had similar problem on a Cisco WS-C2940-8TF-S.
This whas the config before (obviously 123456 is just to cover private informations):
hostname 123456
enable secret level 15 0 123456
enable secret level 5 0 123456
username 123456A privilege 15 secret 0 123456
username 123456B privilege 15 secret 0 123456
username 123456C privilege 5 secret 0 123456
aaa new-model
aaa authentication login defaut local
aaa authorization exec default local
line con 0
line vty 0 4
exec-timeout 60 0
transport input ssh
line vty 5 15
exec-timeout 60 0
transport input ssh
I added these lines to solve it.
     conf terminal
     aaa authorization exec Console none
     line con 0
     ^Z
Alex
