CRS 5.0 with Callmanager 5.1
Answered Question
Jul 21st, 2008
Hi all,
I have an existing preinstalled CRS 5.0 that I configured to work with another Callmanager Cluster. So it is not a new installed CRS. The scripts work fine but when I want to assign ressources to ICD on the end user page there is no field "IPCC Extension", because the Enterprise Parameter say "IPCC Express installed = false".
Is there a way beside a clean new install to make this parameter become "true".
I mean otherwise what is the benefit of the "change cluster" in CRS???
Thanks in advance for your ideas and help.
Kind Regards,
Markus
Correct Answer by aghaznavi about 8 years 8 months ago
You can update this parameter by running this command on the CCM Publisher in CLImode: run sql update processconfig set paramvalue="T" where paramname like '%nstalled%'.
Overall Rating: 5 (1 ratings)
Correct Answer
aghaznavi Fri, 07/25/2008 - 10:42
  • Silver, 250 points or more
markus.thelen Tue, 07/29/2008 - 06:52
Great!!! It works. Thanks a lot for you help.
Kind Regards,
Markus
