WIC 1DSU T1 puzzler
Jul 21st, 2008
I have a 1721 router with at WIC 1DSU T1(version 1) card. The router is running a static VPN tunnel to another site. With all of the IP services running and traffic the router is hitting 90% and dropping VOIP traffic. I upgraded the router to a 2811 with a WIC 1DSU T1 V2 card. The router dropps every other ping and traffice but it doesn't sho up in a <sho int> command. I upgraded to IOS version c2800nm-advsecurityk9-mz.124-15.T5.bin. Is there a compatibility with the DSLAM? The routers have somewhat of the same config on them. Any suggestions? BTW I think that the ISP us spoofing a frame-relay connection and it is really ATM.
Giuseppe Larosa Sat, 07/26/2008 - 13:01
Hello Jason,
you should provide more information in order to get some help.
Interface configuration
sh frame-rel pvc
sh frame-rel lmi
Your provider can give you a FR PVC that is switched to an ATM pvc by using service interworking.
Your interface should be a serial interface with FR encapsulation not an ATM T1.
If the interface isn't up/up the router can't use it for traffic.
On the CO side there is a FR switch not a DSLAM.
Give a look at the following:
http://www.cisco.com/en/US/docs/ios/12_4/interface/configuration/guide/ht1dsu.html
Notice there are some new commands about physical layer
Prerequisites
The following are prerequisites to enable the T1 CSU WIC:
•Leased line from your telephone company
•Configuration parameters as specified by your telephone company. For most connections, the following default settings should suffice:
-service-module t1 clock source line
-service-module t1 data-coding normal
-service-module t1 timeslots all speed 64
-service-module t1 framing esf
-service-module t1 lbo none
-service-module t1 linecode b8zs
-no service-module t1 remote-alarm-enable
-no service-module t1 fdl
Hope to help
Giuseppe
