ACE license
cfolkerts
Does anyone know if the ACE license needs to the upgraded if we are going to upgrade the version of code?
The reason I ask is because we have an old license for the ACE module and when I upgrade the code, I am unable to create more than two contexts (Admin and another). The ACE spits out an error that says the ACE has no more room.
Thanks for your replies.
I have seen this error before. (Not for context creation but while doing some other config).
It means that ACE's Linux file system has no more space left. Cisco TAC can help you clean up the stuck temporary files.
You can also try to reload ACE (If its possible).This may remove the temp/stuck files from the file system.
Syed Iftekhar Ahmed
9 Replies 9
sachinga.hcl
Level 4
Level 4
HI Clifton ,
Give me the details of the license using following commands in your admin context :
host1/Admin# show version
host1/Admin# show license brief
# show license status
# show license usage
Also tell me what is your current software version.
And which software version you are planning to upgrade.
I will come up with more specific answer then.
As per my understanding :
The ACE comes preloaded with the operating system software. To take advantage of new features and bug fixes, you can upgrade your ACE with a new version of software when it becomes available.
In the Admin context, you will use the copy command in Exec mode to manually upgrade the ACE software. After the software installation is finished, set the boot variable and configuration register to autoboot the software image. Then, reboot the appliance to load the new image.
To minimize any disruption to existing network traffic during a software upgrade or downgrade, deploy your ACE appliances in a redundant configuration
1. Changing the Admin Password
Before you upgrade to software version A1(8.0a) or higher, you must change the default Admin password if you have not already done so. Otherwise, after you upgrade the ACE software, you will only be able to log in to the ACE through the console port.
2. Changing the www User Password
Before you upgrade to software version A1(8.0a) or higher, you must change the default www user password if you have not already done so. Otherwise, after you upgrade the ACE software, the www user will be disabled and you will not be able to use Extensible Markup Language (XML) to remotely configure an ACE until you change the default www user password.
3. Creating a Checkpoint
I strongly recommend that you create a checkpoint in the running-configuration file of each context in your ACE. A checkpoint creates a snapshot of your configuration that you can later roll back to in case a problem occurs with an upgrade and you want to downgrade the software to a previous release. Use the checkpoint create command in Exec mode in each context for which you want to create a configuration checkpoint and name the checkpoint.
To display the software image on the ACE, use the show version command in Exec mode. The syntax for this command is:
show version
For example, enter:
TAC support: http://www.cisco.com/tac
Copyright (c) 1985-2007 by Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained herein are owned by
other third parties and are used and distributed under license.
Some parts of this software are covered under the GNU Public
License. A copy of the license is available at
http://www.gnu.org/licenses/gpl.html.
Software
loader: Version 0.95
system: Version A1(7.0) [build 3.0(0)A1(7.999.31)
adbuild_22:46:11-2008/04/
07_/auto/adbure_nightly2/nightly_scimitar-a18-rib/REL_3_0_0_A1_7_999
system image file: (nd)/192.168.65.34/scimitar.bin
Device Manager version 1.0 (0) 20080408:0435
installed license: ACE-AP-VIRT-020 ACE-AP-OPT-LIC-K9
ACE-AP-SSL-10K-K9
Hardware
cpu info:
number of cpu(s): 1
cpu type: Pentium(R)
cpu: 0, model: Intel(R) Pentium(R) 4, speed: 3399.991 MHz
memory info:
total: 6226704 kB, free: 4638636 kB
shared: kB, buffers: 19300 kB, cached 0 kB
cf info:
filesystem: /dev/hdb2
total: 861668 kB, used: 348552 kB, available: 469344 kB
last boot reason: reload command by root
configuration register: 0x1
switch kernel uptime is 0 days 18 hours 52 minute(s) 58 second(s)
By default, the ACE supports the following features and capabilities:
• Virtualization: 1 admin context and 5 user contexts
(by adding licence you cna upgrade cuser context upto 20)
• Hypertext Transfer Protocol (HTTP) compression: 100 megabits per second (Mbps)
You can increase the performance and operating capabilities of your ACE product by purchasing one of the licensing options.
There are two methods to order your ACE product:
• Ordering separate license options.
ACE demo licenses are available through your Cisco account representative. A demo license is valid for only 60 days. At the end of this period, you must update the demo license with a permanent license to continue to use the ACE software. To view the expiration of a demo license, use the show license usage command in Exec mode.
If you need to replace the ACE, you can copy and install the license file for the license onto the replacement appliance.
The ACE demo license is valid for only 60 days. Four weeks before the license expires, the ACE generates warning syslog messages once a day. During the final week, a warning syslog message occurs once an hour. Before this period ends, you must update the demo license with a permanent license. Otherwise, the ACE will revert to its previous throughout performance, SSL TPS, or number of contexts.
If you replace the context demo license with a permanent license, you can continue to use the configured user contexts on the ACE. However, if you allow a context license to expire, the ACE automatically removes all user contexts from the Admin running configuration and all configurations for the user contexts. Before a context license expires, save the Admin running configuration and the user context running configurations to a remote server.
To view the expiration of the demo license, use the show license usage command in Exec mode from the Admin context.
After you copy the permanent license file to the ACE, you can install it. To replace a demo license with a permanent license, use the license update disk0: command in Exec mode from the Admin context. The syntax of this command is:
license update disk0:[path/]permanent_filename demo_filename
The keyword and arguments are:
• demo_filename-Filename for the demo license file that the permanent license file is replacing.
For example, enter:
host1/Admin# license update disk0:ACE-AP-VIRT-020.lic
ACE-AP-VIRT-020-DEMO.lic
(But please dont execute any of the configutration upgrade commands until you know about all the steps regarding the upgradation process.)
When you enter the clear startup-config or the write erase command, the ACE does not remove license files from the startup-configuration file. You must use the license uninstall command to remove license files from the ACE.
The show commands that you can use to display license information about your ACE. To display license information, use the show license command in Exec mode from the Admin context. The syntax for this command is:
1. host1/Admin# show license brief | file filename | internal event-history | status | usage
The options and arguments for this command are:
• file filename-Displays the file contents of the specified license
• status-Displays the status of licensed features
•Usage-Displays the usage table for all licenses
Entering the show license command without any options and arguments displays all installed ACE license files and their contents.
For example, to display a list of the current installed licenses, enter
2. host1/Admin# show license brief
ACE-AP-VIRT-020.lic
ACE-AP-OPT-LIC-K9.lic
ACE-AP-SSL-10K-K9.lic
You can also use the two command given below to see more details regarding license:
3.host1/Admin# show license status
4. host1/Admin# show license usage
You can also view the ACE license by using the show version command in Exec mode on the ACE.
Hope it will bring something useful information for you.
I am just sharing my vision with you. Correct me if I am wrong. Also looking forward to speak more regarding this for you after knowing which version of software you are using currently.
Till then ,
Kind Regards,
Sachinga@hcl.in
Below is the output from my primary ACE.
MP-ACE-1/Admin# show ver
Cisco Application Control Software (ACSW)
Copyright (c) 2002-2006, Cisco Systems, Inc. All rights reserved.
Software
loader: Version 12.2[120]
system: Version 3.0(0)A1(6.2) [build 3.0(0)A1(6.2) adbuild_23:41:40-2007/10/18_/auto/adbure-rel2/ws/REL_3_0_0_A1_6_2]
system image file: [LCP] disk0:c6ace-t1k9-mz.3.0.0_A1_6_2.bin
installed license: ACE-VIRT-020 ACE-SEC-LIC-K9 ACE-SSL-10K-K9
Hardware
Cisco ACE (slot: 7)
cpu info:
number of cpu(s): 2
cpu type: SiByte
cpu: 0, model: SiByte SB1 V0.2, speed: 700 MHz
cpu: 1, model: SiByte SB1 V0.2, speed: 700 MHz
memory info:
total: 957652 kB, free: 335560 kB
shared: 0 kB, buffers: 2536 kB, cached 0 kB
cf info:
filesystem: /dev/cf
total: 1000512 kB, used: 417264 kB, available: 583248 kB
last boot reason: reload command by admin
MP-ACE-1 kernel uptime is 12 days 1 hours 47 minute(s) 0 second(s)
MP-ACE-1/Admin# show license brief
ACE20071213084951175.lic
MP-ACE-1/Admin# show license status
Licensed Feature Count
SSL transactions per second 10000
Virtualized contexts 20
Module bandwidth in Gbps 4
MP-ACE-1/Admin# show license usage
License Ins Lic Status Expiry Date Comments
Count
ACE-08G-LIC No - Unused -
ACE-16G-LIC No - Unused -
ACE-UPG1-LIC No - Unused -
ACE-UPG2-LIC No - Unused -
ACE-VIRT-020 Yes 1 In use never -
ACE-VIRT-050 No - Unused -
ACE-VIRT-100 No - Unused -
ACE-VIRT-250 No - Unused -
ACE-VIRT-UP1 No - Unused -
ACE-VIRT-UP2 No - Unused -
ACE-VIRT-UP3 No - Unused -
ACE10-16G-LIC No - Unused -
ACE-SEC-LIC-K9 Yes 1 Unused never -
ACE-SSL-05K-K9 No - Unused -
ACE-SSL-10K-K9 Yes 1 In use never -
ACE-SSL-15K-K9 No - Unused -
ACE-SSL-20K-K9 No - Unused -
ACE-SSL-UP1-K9 No - Unused -
ACE-SSL-UP2-K9 No - Unused -
ACE-SSL-UP3-K9 No - Unused -
MP-ACE-1/Admin#
And here is the license I am trying to upgrade to along with the error.
Software
system: Version 3.0(0)A1(6.3c) [build 3.0(0)A1(6.3c) adbuild_18:08:08-2008/06/17_/auto/adbu-rel3/ws/rel_3_0_0_a1_6.3-throttle/R
EL_3_0_0_A]
system image file: [LCP] disk0:c6ace-t1k9-mz.3.0.0_A1_6_3c.bin
Hardware
Cisco ACE (slot: 7)
cpu info:
number of cpu(s): 2
cpu type: SiByte
memory info:
total: 957628 kB, free: 352220 kB
shared: 0 kB, buffers: 1096 kB, cached 0 kB
cf info:
filesystem: /dev/cf
last boot reason: reload command by cfolkerts
MP-ACE-1 kernel uptime is 0 days 0 hour 4 minute(s) 32 second(s)
MP-ACE-1/Admin# show context
Number of Contexts = 1
Name: Admin , Id: 0
Config count: 35
Description:
Resource-class: RC1
FT Auto-sync running-cfg configured state: enabled
FT Auto-sync running-cfg actual state: enabled
FT Auto-sync startup-cfg configured state: enabled
FT Auto-sync startup-cfg actual state: enabled
MP-ACE-1/Admin# config t
Enter configuration commands, one per line. End with CNTL/Z.
MP-ACE-1/Admin(config)# context WWW
MP-ACE-1/Admin(config-context)# member RC1
MP-ACE-1/Admin(config-context)# context OWA
Context creation failed : No space left on device
MP-ACE-1/Admin(config)# do show license brief
MP-ACE-1/Admin(config)# do show license usage
Count
MP-ACE-1/Admin(config)# do show license status
AS per the licensing details. You should be able to create 20 contexts.
What are the exact Wordings of the error you are getting?
Syed Iftekhar Ahmed
From the above output, below is the error I receive.
Syed Iftekhar Ahmed
There was no space left on my disk0: which caused the issue. Thanks
