Cisco2950 and QoS
Jul 21st, 2008
I have a simple network with 4 Catalyst 2940 - 48 port switches with the EI image. We use a BCM400 Nortel VOIP product. VOIP phones are plugged into data jacks and computers into the phones. Here is my current config (reduced) from the switch that connects to the BCM:
nnblsw1# sh run
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname nnblsw1
no logging on
enable secret xxx
clock timezone MST -7
clock summer-time MDT recurring 2 Sun Mar 2:00 1 Sun Nov 2:00
ip subnet-zero
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
interface FastEthernet0/1
switchport mode trunk
interface FastEthernet0/2
description BCM400 LAN connection
switchport mode access
interface FastEthernet0/30
description WAN Connection
speed 10
duplex full
interface FastEthernet0/46
description BCM VOIP connection
switchport access vlan 2
interface FastEthernet0/48
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
ip address 192.168.11.117 255.255.255.0
no ip route-cache
ip default-gateway 192.168.11.1
ip http server
logging trap debugging
logging facility daemon
logging 10.1.10.105
snmp-server community ?123! RO
nnblsw1#
Note, all ports except the port that plugs into the BCM VOIP port are in VLAN 1. I want to enable QoS on the catalyst switches. I read through the Configuring QoS document from Cisco, but I am more that a little confused. My goal is to give VOIP traffic a higher priority than data traffic.
michaelchoo Mon, 07/21/2008 - 16:19
The simplest way is to configure AutoQoS on the appropriate ports, which will generate all the necessary QoS configurations on the switch. Simply invoke the "auto qos voip trust" command on the interface connected to the BCM as well as on the inter-switch link(s).
murray-davis Wed, 07/23/2008 - 09:14
Is there not two parts of this and should not the auto qos voip trust command be done at the global config level, i.e.
config t
auto qos voip trust
mls qos trust cos
Collin Clark Wed, 07/23/2008 - 09:31
  • Purple, 4500 points or more
You need to apply auto qos to all interface where a phone could be connected.
<font size="2">interface range fa0/1 - 48</p><p>auto qos voip trust</p><p>mls qos trust dscp</p><p>priority-queue out</p><p></font>
You don't need to apply these commands to trunk ports, but you can, it won't hurt anything. Also note that Nortel uses CS3 for call signaling, where Cisco uses CS5. You'll need to remap or change the BCM to match Cisco.
remapping
mls qos srr-queue output dscp-map queue 1 threshold 3 31 41 42 43 44 45 46 47
mls qos srr-queue input dscp-map queue 2 threshold 3 24 25 26 27 28 29 30 40
Hope that helps.
andrew.butterworth Wed, 07/23/2008 - 10:02
  • Gold, 750 points or more
I think you are a little confused there Coling ;o)
The switch in question is a 2950, the commands you posted are for the 2960, 3560 & 3750. You also state Nortel uses CS3 for Call Signalling and Cisco use CS5. It is actually the other way around Nortel use CS5 (by default) and Cisco use either CS3 or AF31 by default depending on software version and what hardware.
I personally wouldn't use Auto-QoS as I don't believe the configuration it generates will suit a lot of scenarios. I prefer to put the extra mile in and configure it manually.
Queuing on the 2950 is Global and is configured with the command 'wrr-queue'. There are 4 egress queues per interface and only CoS values can be mapped to queues (map the internal DSCP value to CoS and then CoS to queue). By default all 4 queues have the same weight:
wrr-queue bandwidth 25 25 25 25
Queue 4 can be an expedite queue if you make it's weight 0. This is the configuration I have on a 2950 EI:
wrr-queue bandwidth 5 25 70 0
wrr-queue cos-map 1 1
wrr-queue cos-map 2 0
wrr-queue cos-map 3 2 3 4 6 7
wrr-queue cos-map 4 5
Here I have given Queue 1 5% of the scheduler, Queue 2 25%, Queue 3 70% and Queue 4 is an expedite queue. I have also changed the CoS-to-Queue mappings so CoS 1 goes to Queue 1, CoS 0 to Queue 2, CoS 2,3,4,6, & 7 to Queue 3 and CoS 5 to Queue 4.
The 2950 is unique amongst the IOS Catalysts in that QoS cannot be turned off, also it doesn't remark CoS & DSCP to 0 on untrusted ports. You would need to write a ingress service-policy if you want to remark incoming CoS or DSCP values.
Andy
