Cisco Network Assistant
Jul 21st, 2008
Hello is there a way I can use this software because I cannot connect using my 1600 series router because it is not compatable. Is there a demo mode of the software so that I can practice Thank you
Sushil Kumar Katre Tue, 07/22/2008 - 00:04
  • Gold, 750 points or more
I am not clear about your 1600 query.
However if you have CCO ID you can download CNA from the below stated link -
http://www.cisco.com/cgi-bin/apps/tblbld/tablebuild.pl?topic=279230132
-> Sushil
EDIT - looks like the above link is not working.
Go to -http://tools.cisco.com/support/downloads/go/Redirect.x?mdfid=268438038
Expand LAN Switches tab
Click on Cisco Catalyst 2950 Series Switches
Click on Cisco Catalyst 2950 12 Switch
Click on Cisco Network Assistant
aconticisco Tue, 07/22/2008 - 11:12
Yes in fact I already have the software downloaded but I cannot use it since my router is not compatable. What I mean is that cannot access the settings of the CNA and all it tells me when o open the software is to try to connect to a router
Sushil Kumar Katre Tue, 07/22/2008 - 19:49
If you mean to say that you stil want to use CNA to access a 1600 router considering the fact that CNA does not supports 1600 then the answer would be no.
-> Sushil
