ASA 5505 connection problem to WAN
Answered Question
required end result:
ASA connected to outside via 8 port switch 63.x.y.0/24
ASA connected to inside via cisco 3560 switch. using 192.168.255.1-2, vlan 255
internal network contain 3 subnets - 200-202.x/24
my problem:
I've started to config my new ASA.
at this point ASA is connected to
1. outside 63.x.y.26 to an 8 port switch that connect to my ISP routers at 63.x.y.1
I've used regular cable and tried cross cable to make sure this is not the problem). lights on both ends show green, the interface show up-up
2. 192.168.200.4 to a laptop at 192.168.200.2
ASA# sh route
Gateway of last resort is 63.x.y.26 to network 0.0.0.0
C 192.168.200.0 255.255.255.0 is directly connected, inside
C 127.1.0.0 255.255.0.0 is directly connected, _internal_loopback
C 63.x.y.0 255.255.255.0 is directly connected, outside
S* 0.0.0.0 0.0.0.0 [1/0] via 63.x.y.26, outside
tracing doen't even get to the D\G and ping to the laptop (I connect to ASA via this laptop using both console and application)
ASA# trace 128.1.1.1
Tracing the route to 128.1.1.1
1 * * *
2 *
ASA# ping 192.168.200.2
Sending 5, 100-byte ICMP Echos to 192.168.200.2, timeout is 2 seconds:
Success rate is 0 percent (0/5)
I'll post the full config Separately
Correct Answer by husycisco about 8 years 8 months ago
Ofir,
First issue the following
no access-group outside_access_in in interface outside
no access-group outside_access_out out interface outside
Check the following
1)ASA can ping 63.x.y.1
2)Laptop is plugged int Vlan1 Port of ASA!
3)Laptop has got an IP address in 192.168.200.0/24 and has the gateway IP of 192.168.200.4.
4)Make sure Laptop can ping 192.168.200.4
5)Make sure Laptop has got a preferred DNS server IP of 4.2.2.2, not anything else, especially NOT 192.168.200.4 as DNS server
6)Make sure browser of Laptop does not have a proxy set.
7)Issue clear arp in ASA and arp -d couple of times in Laptop
Hello Ofir,
Do the following modifications
no route outside 0.0.0.0 0.0.0.0 63.x.y.26 1
route outside 0.0.0.0 0.0.0.0 63.x.y.1 1
clear arp
no icmp permit 192.168.200.0 255.255.255.0 inside
no icmp permit 192.168.201.0 255.255.255.0 inside
no icmp permit 192.168.202.0 255.255.255.0 inside
no icmp deny any inside
no icmp deny any outside
no icmp permit any inside
no icmp permit any outside
policy-map global_policy
class inspection_default
inspect icmp
Overall Rating: 5 (2 ratings)
FULL CONFIG
***************************************************************************8
ASA# sh run
: Saved
ASA Version 7.2(3)
hostname ASA
domain-name domain.COM
enable password xxx
names
dns-guard
interface Vlan1
description Management
nameif inside
security-level 100
ip address 192.168.200.4 255.255.255.0
interface Vlan2
description WAN
nameif outside
security-level 0
ip address 63.x.y.26 255.255.255.0
interface Vlan255
description ASA to LAN (192.168.255.2)
nameif inside255
security-level 100
ip address 192.168.255.1 255.255.255.252
interface Ethernet0/0
description WAN - connection to Verizon's network
switchport access vlan 2
interface Ethernet0/1
description VLAN255 to LAN
switchport access vlan 255
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
passwd xxx
ftp mode passive
clock timezone EST -5
clock summer-time EDT recurring
dns domain-lookup inside
dns server-group DefaultDNS
dns server-group dsnserver
name-server 192.168.200.x
name-server 192.168.200.y
domain-name domain.com
same-security-traffic permit inter-interface
pager lines 24
mtu inside 1500
mtu outside 1500
mtu inside255 1500
ip verify reverse-path interface outside
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-523.bin
asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 0.0.0.0 0.0.0.0
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
http server enable
http 192.168.200.0 255.255.255.0 inside
snmp-server location Server Room
snmp-server enable traps snmp authentication linkup linkdown coldstart
snmp-server enable traps syslog
snmp-server enable traps ipsec start stop
telnet 192.168.200.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 15
management-access inside
dhcpd auto_config outside
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
ntp server 192.43.244.18 source outside prefer
ntp server 207.46.232.182 source outside
prompt hostname context
Cryptochecksum:xxx
: end
a.alekseev Mon, 07/21/2008 - 14:04
  • Gold, 750 points or more
do modifications and try again
if it doesn't work show the output "sh arp"
Correct Answer
husycisco Mon, 07/21/2008 - 16:14
Hello Ofir,
clear arp
inspect icmp
a.alekseev - your solution didn't work but husycisco's did.
I can't check the LAN connections during day time but the outbound connection is working.
I just want to make sure, it is OK to leave ASA side by side with the current firewall as long as I use different IPs? doing so I can test all my outside related connections during day time and save time
also, what do I have to configure to make my laptop (192.168.200.2) go to the internet via ASA?
thanks,
Ofir
husycisco Tue, 07/22/2008 - 07:43
Ofir,
"I just want to make sure, it is OK to leave ASA side by side with the current firewall as long as I use different IPs?"
Sure it is.
"doing so I can test all my outside related connections "
Yes,
"also, what do I have to configure to make my laptop (192.168.200.2) go to the internet via ASA?"
Add the following commands
"Edited" You should be able to connect to internet once you set a correct DNS server to laptop. Set DNS as 4.2.2.2, assuming that the laptop is directly connected to ASA inside interface not inside255
it did not work. still can't access outside via laptop
this is what I had before:
ASA# sh run | inc nat
access-list inside_nat0_outbound extended permit ip interface inside host 69.x.y.82
I've removed it and added this:
nat (inside) 1 0 0
now I get this:
this is my FULL CONFIG after these changes:
ASA# sh run
: Saved
ASA Version 7.2(3)
hostname ASA
enable password xxx
names
dns-guard
interface Vlan1
nameif inside
security-level 100
interface Vlan2
description WAN
nameif outside
security-level 0
interface Vlan255
nameif inside255
security-level 100
passwd xxx
ftp mode passive
dns server-group DOMAINinside
name-server 192.168.201.y
domain-name ogsny.domain.com
pager lines 24
mtu inside 1500
mtu outside 1500
mtu inside255 1500
no failover
asdm history enable
arp timeout 14400
http server enable
telnet timeout 5
ssh timeout 5
console timeout 15
parameters
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect icmp
smtp-server 192.168.200.12
Cryptochecksum:xxx
: end
Correct Answer
husycisco Tue, 07/22/2008 - 09:13
Ofir,
Check the following
husycisco Tue, 07/22/2008 - 09:45
You are welcome Ofir and thanks for rating. Please do not hesitate to post here if you encounter difficulties implementing into production network after your tests are finished.
