7940 not registering to our UC520, other phones do
Jul 21st, 2008
I am sort of new to the phone IP setup and most of the stuff I have learnt so far is self taught or from other colleagues.
My extent with the IP Phones is setting up a UC500 using the CA and then customising the ephones, dn and incoming trucks in the CLI.
This issue I have at the moment is that I upgraded the files CUE and IOS on the UC520 and now new 7940 phones will not automatically register correctly to the UC520 (our 7911 phones will).
The phone seems to
Self test ok
Configures VLAN
Get IP number
Connect to UC520 TFTP server
Download default xml
Load correct file
After that is gets stuck between
Configurating IP and File Not Found SEP001FCA362F40.cnf.xml
I have checked the MAC number and it is correct and checked the files on the unit against the files in the startup config and they appear to be correct. Unsure of the next step
Here is an attached debug file
5073: 005071: Jul 21 17:31:44.663: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/1/4, changed state to up
5074: 005072: Jul 21 17:31:56.663: TFTP: Looking for CTLSEP001FCA362F40.tlv
5075: 005073: Jul 21 17:31:56.683: TFTP: Looking for SEP001FCA362F40.cnf.xml
5076: 005074: Jul 21 17:31:56.703: TFTP: Looking for SIP001FCA362F40.cnf
5077: 005075: Jul 21 17:31:56.735: TFTP: Looking for MGC001FCA362F40.cnf
5078: 005076: Jul 21 17:31:56.755: TFTP: Looking for XMLDefault.cnf.xml
5079: 005077: Jul 21 17:31:56.755: TFTP: Opened system:/its/XMLDefault.cnf.xml, fd 10, size 3072 for process 142
5080: 005078: Jul 21 17:31:56.767: TFTP: Finished system:/its/XMLDefault.cnf.xml, time 00:00:00 for process 142
5081: 005079: Jul 21 17:31:56.855: TFTP: Looking for P00308000500.loads
5082: 005080: Jul 21 17:31:56.875: TFTP: Opened flash:P00308000500.loads, fd 10, size 458 for process 142
5083: 005081: Jul 21 17:31:56.887: TFTP: Finished flash:P00308000500.loads, time 00:00:00 for process 142
5084: 005082: Jul 21 17:32:06.727: TFTP: Looking for CTLSEP001FCA362F40.tlv
5085: 005083: Jul 21 17:32:06.791: TFTP: Looking for SEP001FCA362F40.cnf.xml
5086: 005084: Jul 21 17:32:06.875: TFTP: Looking for XMLDefault.cnf.xml
5087: 005085: Jul 21 17:32:06.875: TFTP: Opened system:/its/XMLDefault.cnf.xml, fd 10, size 3072 for process 142
5088: 005086: Jul 21 17:32:06.895: TFTP: Finished system:/its/XMLDefault.cnf.xml, time 00:00:00 for process 142
5089: 005087: Jul 21 17:32:10.323: TFTP: Looking for CTLSEP001FCA362F40.tlv5090: 00
5088: Jul 21 17:32:10.387: TFTP: Looking for SEP001FCA362F40.cnf.xml
5091: 005089: Jul 21 17:32:10.471: TFTP: Looking for XMLDefault.cnf.xml
5092: 005090: Jul 21 17:32:10.471: TFTP: Opened system:/its/XMLDefault.cnf.xml, fd 10, size 3072 for process 142
5093: 005091: Jul 21 17:32:10.487: TFTP: Finished system:/its/XMLDefault.cnf.xml, time 00:00:00 for process 142
5094: 005092: Jul 21 17:32:13.911: TFTP: Looking for CTLSEP001FCA362F40.tlv
5095: 005093: Jul 21 17:32:13.975: TFTP: Looking for SEP001FCA362F40.cnf.xml
5096: 005094: Jul 21 17:32:14.059: TFTP: Looking for XMLDefault.cnf.xml
5097: 005095: Jul 21 17:32:14.059: TFTP: Opened system:/its/XMLDefault.cnf.xml, fd 10, size 3072 for process 142
5098: 005096: Jul 21 17:32:14.079: TFTP: Finished system:/its/XMLDefault.cnf.xml, time 00:00:00 for process 142
5099: 005097: Jul 21 17:32:17.503: TFTP: Looking for CTLSEP001FCA362F40.tlv
5100: 005098: Jul 21 17:32:17.567: TFTP: Looking for SEP001FCA362F40.cnf.xml
5101: 005099: Jul 21 17:32:17.647: TFTP: Looking for XMLDefault.cnf.xml
5102: 005100: Jul 21 17:32:17.651: TFTP: Opened system:/its/XMLDefault.cnf.xml, fd 10, size 3072 for process 142
5103: 005101: Jul 21 17:32:17.667: TFTP: Finished system:/its/XMLDefault.cnf.xml, time 00:00:00 for process 142
5104: 005102: Jul 21 17:32:21.091: TFTP: Looking for CTLSEP001FCA362F40.tlv
5105: 005103: Jul 21 17:32:21.155: TFTP: Looking for SEP001FCA362F40.cnf.xml
owillins Fri, 07/25/2008 - 08:45
  • Silver, 250 points or more
Confirm that your Cisco IP Phone is not receiving the correct CallManager addresses by using the Settings button on your IP phone and then selecting Network Configuration. Troubleshooting Cisco IP Phone Registration Problems with Cisco CallManager 3.x and 4.x.
http://www.cisco.com/en/US/products/hw/phones/ps379/products_tech_note09186a008009485a.shtml
a.gooding Wed, 03/25/2009 - 04:23
  • Bronze, 100 points or more
did you ever get this resolved. i configure the first five phones fine. i then used the template to do a bulk import. when i plugged in all the other 521 phones they all give me this downloading XMLDefault.cnf.xml and its stuck there. what i noitced is that for some reason it is not picking up the TFTP server IP.
