Fax forwarding with number dialed
Jul 21st, 2008
I need to be able to forward a fax line to another line and have the end phone number see the number that was dialed originally. Like this 1234 dials fax 2222, 2222 is forwarded to 3333, 3333 needs to see the incoming call being from 2222 and not from 1234. Hope this makes sense and somebody has an answer because Cisco hasn't yet! I'm on CM 4.1.3
aghaznavi Fri, 07/25/2008 - 08:46
Make sure you are using supported version software and supported router. Or Some of the extension or trunks are blocked verified that one.
