Router CPU usage goes high!
Answered Question
Jul 21st, 2008
My company has ~400 users. I use a 2801 router to route traffic between vlans ('cause we just have some layer 2 catalysts and this router) and nat for internet access. Our network model looks like this: IPS -> Router -> users. On subinterfaces, I've already used:
no ip redirects
no ip unreachables
no ip proxy-arp
But the cpu usage still goes high around 70~80%.
Do u have any ideas to reduce the cpu usage?
Correct Answer by Justin Brenton about 9 years 5 days ago
Hi dattx_fis2,
Is the 2801 being used for IP phones as well?
Have you turned off all debugging?
Try this
http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a00800a70f2.shtml
HTH, Please rate if so.
Justin
Overall Rating: 4 (1 ratings)
dattx_fis2 Tue, 07/29/2008 - 01:09
Tks Justin.
All debbing are turned off and we don't use IP phones. I think the traffic load is so high and maybe some PCs have virus. I'm going to change the interrupt request timer by changing scheduller allocate command
a.alekseev Tue, 07/29/2008 - 01:11
  • Gold, 750 points or more
show the output
#sh proc cpu sorted 5min
or
#sh proc cpu | e 0\.00
#sh ip traffic
dattx_fis2 Tue, 07/29/2008 - 02:12
I think I find the reason: I use both netflow and snmp on the router, snmp traps send to 2 mgmt servers. The router is polled too often so the cpu usage goes high
