MGCP registration
Jul 22nd, 2008
Hi Guys,
I am setting up a couple of fxo ports on an mgcp gateway and for some reason cannot get the ports to register. Here is some output from :
access-hcmc-cs#sh mgcp
MGCP Admin State ACTIVE, Oper State ACTIVE - Cause Code NONE
MGCP call-agent: none Initial protocol service is MGCP 0.1
MGCP validate call-agent source-ipaddr DISABLED
MGCP validate domain name DISABLED
MGCP block-newcalls DISABLED
MGCP send SGCP RSIP: forced/restart/graceful/disconnected DISABLED
MGCP quarantine mode discard/step
MGCP quarantine of persistent events is ENABLED
MGCP dtmf-relay for VoIP is SDP controlled
MGCP dtmf-relay for voAAL2 is SDP controlled
MGCP voip modem passthrough disabled
ccm-manager mgcp
ccm-manager config server 163.184.222.18 163.184.222.34
ccm-manager config
access-hcmc-cs#sh ccm-manager
MGCP Domain Name: access-hcmc-cs.cisco.sinet.slb.com
Priority Status Host
Primary None
First Backup None
Second Backup None
Current active Call Manager: None
Backhaul/Redundant link port: 2428
Failover Interval: 30 seconds
Keepalive Interval: 15 seconds
Last keepalive sent: 04:07:12 GMT Jul 14 2008 (elapsed ti
Last MGCP traffic time: 07:50:06 GMT Jul 22 2008 (elapsed ti
Last failover time: None
Last switchback time: None
Switchback mode: Graceful
MGCP Fallback mode: Not Selected
Last MGCP Fallback start time: None
Last MGCP Fallback end time: None
MGCP Download Tones: Disabled
TFTP retry count to shut Ports: 2
I can ping the ccm successfully from the gateway and checked the host names etc are a 100% match....any ideas ??
Marwan ALshawi Tue, 07/22/2008 - 00:23
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
i cant see the following command:
mgcp
this command will start the mgcp process
try it
Rate if Helpful
Steellllllllll0 Tue, 07/22/2008 - 00:30
Sorry i have that already :
ccm-manager mgcp
ccm-manager config server X.X.X.X X.X.X.X
ccm-manager config
mgcp
Marwan ALshawi Tue, 07/22/2008 - 00:50
have u made a pots dial-peer for mgcp
lets say ur port number is 1/0/0
dial-peer voice 1 pots
application MGCPAPP
port 1/0/0
Steellllllllll0 Tue, 07/22/2008 - 01:32
I have not created any dial-peers....is this not something that is downloaded in the xml file from the ccm ???
Marwan ALshawi Tue, 07/22/2008 - 01:42
try it then let me know
dial peer same as the one above
Steellllllllll0 Tue, 07/22/2008 - 01:47
The application mgcpapp is not a valid command under the dial-peer....wont allow it...
Marwan ALshawi Tue, 07/22/2008 - 01:52
you need to bind MGCP to the voice ports. You do this by configuring a dial peer for each voice port and binding MGCP to it using the application MGCPAPP command. This command is case sensitive in some IOS releases. To be safe, code MGCPAPP (all capital letters) unless you know that your release is not case sensitive.
VoiceGW(config)#dial-peer voice 100 pots
VoiceGW(config-dial-peer)#application MGCPAPP
VoiceGW(config-dial-peer)#port 1/0/0
When you make a change to the MGCP configuration, such as adding or changing endpoints, it is a good idea to reinitialize MGCP by issuing no mgcp and then mgcp global configuration commands
source: cisco press, Cisco Voice Gateways and Gatekeepers , 2006
try it agin
and good luck
hope this helpful
Ayodeji Okanlawon Tue, 07/22/2008 - 02:37
  • Cisco Designated VIP,
    2017 IP Telephony
Have you tried using the command
service mgcp
Marwan ALshawi Tue, 07/22/2008 - 02:42
i think service mgcp or application mgcp
he should tell the port that its controlled by the mgcp-agent
right?
Ayodeji Okanlawon Tue, 07/22/2008 - 02:44
    2017 IP Telephony
The service mgcp, enables the MGCP application on the pots dial-peer.
Although in newer versions of IOS, it is not required. It is just safe to have it there
jamesfang98 Tue, 07/22/2008 - 06:22
Pls place output "show running | inclu mgcp" from your rtr.
The output of 'show mgcp' indicated:
It appears no call-agent defined for mgcp.
Ayodeji Okanlawon Tue, 07/22/2008 - 06:29
    2017 IP Telephony
ALso have a look at this site. Its the best for MGCP configs
