WAAS optimization not working however WAFS works fine
Jul 22nd, 2008
I am testing a WAAS infrastructure with couple of WAE-512 (CM and Core) and NM-502 at edge.
WCCP has been properly configured on the routers and WAAS devices. I have also configured WAFS service and this works fine, however other application optimization like (web,VNC) etc doesn't seem to work, I can see the connection but the applied policy is "None".
I have enabled the default policy on the device group.
Is there anything else i am missing
Overall Rating: 3 (1 ratings)
Zach Seils Tue, 07/22/2008 - 05:36
An applied policy of "None" means that the connection is being handled as pass-through (i.e. not optimized).
Can you please share a topology diagram and router configurations?
sunil_almeida Wed, 07/23/2008 - 00:15
Hi Zach,
problem resolved!!!
Yes it was indeed a misconfiguration.
On the core WAE instead of defining the router WAE sub-interface as a default gateway, i had configured the Switch (L3) as default gateway.
