1801 + url-server (websense)
Answered Question
Jul 22nd, 2008
Is any one using 1801 with url-server (websense)?
I can do it on my PIX 506:
url-server (inside) vendor websense host a.b.c.d timeout 30 protocol
TCP version 4
Is it supported on 1801? Any issues?
Thanks and regards,
lesniak81
Correct Answer by andrew.prince@m... about 8 years 7 months ago
Pawel,
yes it is supported on the 1801, you must be running the below IOS Trains:-
LD Release 12.4(4)T3
ED Release 12.4(20)T 12.4(11)XW7 12.4(11)XJ4 12.4(4)XC7 12.4(2)XA2 12.3(14)YT1 12.3(8)YI3
The image type must be:-
ADV. ENTERPRISE SERVICES or ADVANCED IP SERVICES
HTH.
Overall Rating: 4 (1 ratings)
Correct Answer
andrew.prince@m... Tue, 07/22/2008 - 04:58
Pawel,
HTH.
