CUE transfer-mode attended and ring-back tone
Jul 22nd, 2008
I have a deployment of CCME CUE 3.1 and 4.3, and I use the CUE with transfer-mode attended. In this case when the CUE transmitting an incoming call to a destination, the caller can not hear the ring-back tone. Also in transfer-mode phone that receives the call of CUE does not show the number of the caller.
As I can solve this?
Overall Rating: 5 (1 ratings)
Anonymous (not verified) Mon, 07/28/2008 - 06:20
The behavior you have seen with caller id is normal because since cue 2.4 we use "transfer-mode attended" as a default. In the previous cue 2.2.2 or earlier it uses transfer-mode blind. If you want to use the same function as previous cue version then you can add the command "transfer-mode blind bye-also" in cue configuration.
Refer the bug: CSCse31911
Cristian Boboc Wed, 06/11/2014 - 13:10
Changing the "transfer-mode blind bye-also" fixed my issue too (CUE version 8.6.6).
