CME - SIP, packet size
Jul 22nd, 2008
Hi!
I'm trying to configure a solution that will work via satellite. It will use SIP between two CMEs. There are concerns related to the size of the packets. I don't know exactly what the best configuration for this is.
I would appreciate some advices or having an example of a similar configuration.
Can you help?
Ana
