francisco_1 Tue, 07/22/2008 - 03:08
router(config)#ip dhcp pool room12
router(dhcp-config)#network 172.16.1.0 255.255.255.0
router(dhcp-config)#exit
router(config-if)#ip dhcp excluded-address 172.16.1.1 172.16.1.10
or based on static mapping from MAC
ip dhcp pool room12
host 1.1.1.1
hardware-address aaaa.aaaa.aaaa
The ip dhcp excluded-address command configures the router to exclude 172.16.1.1 through 172.16.1.10 when assigning addresses to clients. The ip dhcp excluded-address command may be used to reserve addresses that are statically assigned to key hosts.
please rate
Rupesh Kashyap Tue, 07/22/2008 - 03:13
You are not getting my question. I have configurd Pool, exclusiona and other setting.
My requirement is for MAC-00.0E.0A should get a fix IP address from Pool. I mean I am looking for IP address reservation based on MAC.
lee.reade Tue, 07/22/2008 - 03:18
3. ip dhcp pool pool-name
4. host address [mask | /prefix-length]
5. client-identifier unique-identifier
6. hardware-address hardware-address type
7. client-name name
Its in the url I posted...best have a look..
LR
francisco_1 Tue, 07/22/2008 - 03:52
sorry i was typing the second part of the config based on static mapping from MAC when you replied.
give it a go and let us know the outcome.
