False Positive alerts in DFM
Jul 22nd, 2008
I'm getting the following alert on one of our 6500's
Here is the alert:
EVENT ID = 0000UGP
ALERT ID = 00006IE
TIME = Tue 22-Jul-2008 03:34:28 EDT
STATUS = Active
SEVERITY = Critical
MANAGED OBJECT = bs029sws01.corp.citistreet.org
MANAGED OBJECT TYPE = Switches and Hubs
EVENT DESCRIPTION = OperationallyDown::Component=IF-bs029sws01.corp.citistreet.org/328 [Lo0] [172.18.254.247];ComponentClass=Interface;ComponentEventCode=1075;Type=SOFTWARELOOPBACK;IsFlapping=false;AdminStatus=UP;MaxSpeed=8000000000;OperStatus=DOWN;InterfaceCode=CODEUNK
CUSTOMER IDENTIFICATION = Networkers
I did a show logging and I see nothing in regards to what the alert is stating.
Please advise.
Joe Clarke Tue, 07/22/2008 - 08:28
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This might only be visible by SNMP, and would point to a bug on the device. Try polling the ifOperStatus of Lo0 to see if it is going down. If the event has since cleared, it may be that the problem was transient, and you'll need a sniffer trace of DFM's polling to catch it again.
dionjiles Tue, 07/22/2008 - 09:53
Hi JClarke,
It seems to be a pattern the alert kicked off around 03:34 Monday am and 03:34 Tuesday am and it clears 4 minutes later. The polling interval is set for 240 seconds.
Joe Clarke Tue, 07/22/2008 - 09:55
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You'll need to start a sniffer trace around that time to capture what DFM is polling. If the switch is really saying Lo0 is down, then we have a device bug. Else there's a problem with DFM.
dionjiles Tue, 07/22/2008 - 10:11
Thanks for the info if it does the same thing in the morning. I will definitely put a sniffer on it to see what's going on during that time frame.
