bulk provisioning service issue
mdaswani
Hello, I am trying to schedule a daily job using the bulk provisioning service.
The job is based on a device pool query and only logs out any users that were logged into the phones.
I schedule the job for a later time and then go to job scheduler and modify it to run daily at 1:00am and activate it. The job does run sucessfully but only once and then goes to a complete status and doesn't run again the next day.
This is CM 6.1(2). Any ideas?
Manish
Hello Manish,
Did you find a solution for this? I am having the same issue (Update Phone query, CUCM 6.1(3) )
Rgds,
Gert-Jan
Hi Gert-Jan,
It sounds like this bug;
CSCsu78938 Bug Details Bug #44 of 176 | < Previous | Next >
Issue with consecutive recurring jobs in BAT
Symptom:
Reoccurring BAT job goes to "Completed" after one run
Conditions:
Submit two consecutive recurring jobs
CUCM 5.x, 6.x, 7.0
Workaround:
None
Further Problem Description:
Issue:
If there is any pending job already on the server, then the recurring job is incorrectly going to completed state after the first run.
Steps to recreate:
- Submit a job with "Run Later"
- Goto Job Scheduler and update the job end time, frequency
- Activate the job
- Repeat the above three steps i.e., submit another recurring job
Expected output:
- First job should get executed and go to pending state after the execution
- Second Job should get executed and this should go to pending state too.
StatusStatus
Fixed
Severity Severity
3 - moderate
Last Modified Last Modified
Any Time
Product Product
Cisco Unified Communications Manager (CallManager)
Technology Technology
1st Found-In 1st Found-in
6.1
5.1(3)
7.0
7.1
Fixed-In Fixed-in
7.1(0.39000.82)
6.1(2.9901.191)
7.1(0.98999.12)
5.1(3.5101.1)
7.0(1.21008.1)
6.1(2.1124.1)
6.0(1.3114.1)
7.0(1.30010.36)
6.1(3.1000.16)
7.0(2.10000.18)
6.1(3.9999.1)
7.1(2.10000.16)
Cheers!
Rob
